우분투 10.10에서 handbrake 동영상 인코딩 프로그램 설치하기
안녕하세요. 스마트폰때문에 동영상 인코딩 프로그램 찾다가 handbrake가 좋다구 해서 설치했습니다.
우분투 10.10 설치방법을 찾던중 구글링에서 찾아서 올립니다~!!
First, you’ll need to add the Handbrake PPA (personal package archive) to your Ubuntu system. Open up a Terminal window and use this command:
[color=#FF0000:3w3365na]sudo add-apt-repository ppa:stebbins/handbrake-snapshots[/color:3w3365na]
After the repository has been added, update your system’s listing of its repositories with this command:
[color=#FF0000:3w3365na]sudo apt-get update[/color:3w3365na]
Once the repository listings have been updated, you can then install the graphical version of Handbrake with this command:
[color=#FF0000:3w3365na]sudo apt-get install handbrake-gtk[/color:3w3365na]
You can also install the command line version of Handbrake with this command:
[color=#FF0000:3w3365na]sudo apt-get install handbrake-cli[/color:3w3365na]
[출처 - http://www.jonathanmoeller.com/screed/?p=2100 ]
cpu사용량이 높네요…7080%정도… (kde라서 그런지…?)
