우분투 8.04에서 spss 설치 중에 문제가 발생
완전 뉴비입니다. ^^;;
일단 인스톨쉴드 위자드에서 막혀버리는 문제는 5시간 동안의 구글링을 통해서 해결했습니다.
다행히 인스톨까지 완료되는데 권한 마법사 부분에서 막혀버리네요. 여기는 터미날에 에러와 함께 나온 메세지입니다.
Locking assertion failure. Backtrace:
#0 /usr/lib/libxcb-xlib.so.0 [0xb7fc4767]
#1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_unlock+0x31) [0xb7fc48b1]
#2 /usr/lib/libX11.so.6(_XReply+0xfd) [0x931081bd]
#3 /tmp/istemp2170250124228/bundledJRE/lib/i386/xawt/libmawt.so [0x9424bd3e]
#4 /tmp/istemp2170250124228/bundledJRE/lib/i386/xawt/libmawt.so [0x94235d47]
#5 /tmp/istemp2170250124228/bundledJRE/lib/i386/xawt/libmawt.so [0x94235ec3]
#6 /tmp/istemp2170250124228/bundledJRE/lib/i386/xawt/libmawt.so(Java_sun_awt_X11GraphicsEnvironment_initDisplay+0x26) [0x94236106]
#7 [0xb1459028]
#8 [0xb1452b6b]
#9 [0xb1452b6b]
#10 [0xb1450234]
#11 /tmp/istemp2170250124228/bundledJRE/lib/i386/server/libjvm.so [0xb76e175c]
#12 /tmp/istemp2170250124228/bundledJRE/lib/i386/server/libjvm.so [0xb78afb48]
#13 /tmp/istemp2170250124228/bundledJRE/lib/i386/server/libjvm.so [0xb76e158f]
#14 /tmp/istemp2170250124228/bundledJRE/lib/i386/server/libjvm.so(JVM_DoPrivileged+0x32d) [0xb773ed7d]
#15 /tmp/istemp2170250124228/bundledJRE/lib/i386/libjava.so(Java_java_security_AccessController_doPrivileged__Ljava_security_PrivilegedAction_2+0x3d) [0xb73eb2cd]
#16 [0xb14588b8]
#17 [0xb1452a94]
#18 [0xb1450234]
#19 /tmp/istemp2170250124228/bundledJRE/lib/i386/server/libjvm.so [0xb76e175c]
#1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_lock+0x2e) [0xb7fc481e]
#2 /usr/lib/libX11.so.6 [0x93107518]
#3 /usr/lib/libX11.so.6(XGetVisualInfo+0x26) [0x930fe0a6]
#4 /tmp/istemp2170250124228/bundledJRE/lib/i386/xawt/libmawt.so [0x94235089]
#5 /tmp/istemp2170250124228/bundledJRE/lib/i386/xawt/libmawt.so [0x942352d3]
#6 /tmp/istemp2170250124228/bundledJRE/lib/i386/xawt/libmawt.so [0x94235f71]
#7 /tmp/istemp2170250124228/bundledJRE/lib/i386/xawt/libmawt.so(Java_sun_awt_X11GraphicsEnvironment_initDisplay+0x26) [0x94236106]
#8 [0xb1459028]
#9 [0xb1452b6b]
#10 [0xb1452b6b]
#11 [0xb1450234]
#12 /tmp/istemp2170250124228/bundledJRE/lib/i386/server/libjvm.so [0xb76e175c]
#13 /tmp/istemp2170250124228/bundledJRE/lib/i386/server/libjvm.so [0xb78afb48]
#14 /tmp/istemp2170250124228/bundledJRE/lib/i386/server/libjvm.so [0xb76e158f]
#15 /tmp/istemp2170250124228/bundledJRE/lib/i386/server/libjvm.so(JVM_DoPrivileged+0x32d) [0xb773ed7d]
#16 /tmp/istemp2170250124228/bundledJRE/lib/i386/libjava.so(Java_java_security_AccessController_doPrivileged__Ljava_security_PrivilegedAction_2+0x3d) [0xb73eb2cd]
#17 [0xb14588b8]
#18 [0xb1452a94]
#19 [0xb1450234]
/usr/share/themes/Human/gtk-2.0/gtkrc:43: error: lexical error or unexpected token, expected valid token
Killed
아마도 이 문제가 해결 안되면…윈도우로 돌아가야 하겠지요.
안그래도 마소하는 짓이 좀 그래서, 서브컴인 노트북부터 리눅스화해볼려고 테스트 중인데ㅜㅜ
힘드네요…도움말씀 부탁드립니다.
어느 글을 참고 하여 설치 중이신지요?
libstdc++5 는 설치 하셨는지요? sudo apt-get install libstdc++5
위 메세지로 봐선 휴먼메타시티 테마 gtkrc 에러 인데… 음
우분투에서 spss 설치
참고 1 : http://forum.ubuntu-fr.org/viewtopic.php?pid=1534272
참고 2 : http://ubuntuforums.org/showthread.php?t=724613
리눅스용 SPSS 16.0은 ubuntu 8.04.1에서 compiz 기능을 끄면 (바탕화면 설정 -> visual effects -> none) 설치/실행 둘 다 됩니다. 하지만 가끔 (특히 기존 sav 자료를 읽어들일때) 한참 동안 멈춰 있는 현상이 발생하고 키보드 입력도 가끔 안되는 문제가 있더군요. – 키보드 입력은 scim과 관련된 문제인 것 같고 scim을 사용하지 않거나 nabi를 대신 사용하면 해결이 됩니다.
참고로 또 다른 통계프로그램인 (SPSS만큼 강력하고 더 작고 가벼운; 윈도용) SigmaStat 3.5가 최신 버전인 wine 1.1.6에서 문제없이 설치되고 실행되더군요. 저는 spss 지우고 이걸 깔아서 사용하고 있습니다.
