우분투 8.1 usb 외장하드 인식 관련
안녕하세요?
다름이 아니라 USB 외장하드가 인식이 안되서 그러는데요…하드는 삼성 80G입니다.(NTFS)
다음과 같은 에러메세지를 띄우면서 안되는데요, 터미널에서 force 옵션을 먹이고 해도 마찬가지입니다. ㅠㅠ
root@ubuntu:/home/sdnrui/바탕화면# mount -t ntfs-3g /dev/sdb1 /usb
$LogFile indicates unclean shutdown (0, 0)
Failed to mount ‘/dev/sdb1’: Operation not supported
Mount is denied because NTFS is marked to be in use. Choose one action:
Choice 1: If you have Windows then disconnect the external devices by
clicking on the ‘Safely Remove Hardware’ icon in the Windows
taskbar then shutdown Windows cleanly.
Choice 2: If you don’t have Windows then you can use the ‘force’ option for
your own responsibility. For example type on the command line:
        mount -t ntfs-3g /dev/sdb1 /usb -o force
Or add the option to the relevant row in the /etc/fstab file:
        /dev/sdb1 /usb ntfs-3g force 0 0
C1은 해당사항이 없고 C2대로 force 옵션을 먹이고 시도해봐도
root@ubuntu:/home/sdnrui/바탕화면# mount -t ntfs-3g /dev/sdb1 /usb force
Usage: mount -V : print version
mount -h : print this help
mount : list mounted filesystems
mount -l : idem, including volume labels
So far the informational part. Next the mounting.
The command is `mount [-t fstype] something somewhere’.
Details found in /etc/fstab may be omitted.
mount -a [-t|-O] … : mount all stuff from /etc/fstab
mount device : mount device at the known place
mount directory : mount known device here
mount -t type dev dir : ordinary mount command
Note that one does not really mount a device, one mounts
a filesystem (of the given type) found on the device.
One can also mount an already visible directory tree elsewhere:
mount --bind olddir newdir
or move a subtree:
mount --move olddir newdir
One can change the type of mount containing the directory dir:
mount --make-shared dir
mount --make-slave dir
mount --make-private dir
mount --make-unbindable dir
One can change the type of all the mounts in a mount subtree
mount --make-rshared dir
mount --make-rslave dir
mount --make-rprivate dir
mount --make-runbindable dir
A device can be given by name, say /dev/hda1 or /dev/cdrom,
or by label, using -L label or by uuid, using -U uuid .
Other options: [-nfFrsvw] [-o options] [-p passwdfd].
For many more details, say man 8 mount .
이런 메세지 뿐입니다.; 초보에게 구원의 손길을 좀 내밀어 주실분 있으면 감사하겠습니다.
참고로 fdisk 정보입니다.
root@ubuntu:/home/sdnrui/바탕화면# fdisk -l
Disk /dev/sda: 8589 MB, 8589934592 bytes
255 heads, 63 sectors/track, 1044 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Disk identifier: 0x00019057
Device Boot Start End Blocks Id System
/dev/sda1 * 1 993 7976241 83 Linux
/dev/sda2 994 1044 409657+ 5 Extended
/dev/sda5 994 1044 409626 82 Linux swap / Solaris
Disk /dev/sdb: 80.0 GB, 80026361856 bytes
255 heads, 63 sectors/track, 9729 cylinders
Disk identifier: 0x6d059b9b
/dev/sdb1 1 9729 78148161 7 HPFS/NTFS
붙여넣기 신공 때문에 글이 길어져서 죄송합니다 :shock:
그냥 외장 하드 끼우고 위치에 서 나오는거 클릭으로 마운트는 되시는 지요?
잘 안되시면 ntfs 니까 xp 에서 디스크 검사 후에 다시 해보시기 바랍니다.
전에 읽은 글에 윈도우즈에서 "안전하게 제거" 인가 (윈도우즈 한참 안써서 기억이 어렴픗하게 나네요.)
해야지 리눅스에서 잘 인식한다고 한것이 기억납니다.
[quote="khrhee":1bo3onzr]전에 읽은 글에 윈도우즈에서 "안전하게 제거" 인가 (윈도우즈 한참 안써서 기억이 어렴픗하게 나네요.)
해야지 리눅스에서 잘 인식한다고 한것이 기억납니다.[/quote:1bo3onzr]
강분도님 khrhee님 두 분 답변 감사합니다. 덕분에 많은 도움이 되었습니다. :D
