우분투 9.04 동영상 재생시 플레이어가 종료됩니다. (totem, mplayer, vlc ...)
eeepc 1000h에 우분투 9,04 alternate 버전으로 설치했습니다.
동영상을 재생하면 플레이어가 꺼집니다.
플레이어 문제인가 해서 mplayer, smplayer, vlc 깔아봤는데 다 그러네요
토템은 그다지 추천해드릴께 못된다고 생각합니다…
VLC 하고 mplayer 가 좋지요.
일단 잡설을 집어치우고…
터미널을열고 vlc 와 mplayer을 실행해보시고 뭐라고 터미널에 뜨는지 적어주시면 감사하겟습니다.
VLC 는 그냥 vlc , mplayer 은 gmplayer 을 입력해야 뜹니다.
VLC 가 vlc 하면 되는지는 확실히 모르겟습니다. 써본적이 없어서요. ㅎㅎ;;
VLC media player 0.9.9a Grishenko
[00000001] main libvlc debug: VLC media player - version 0.9.9a Grishenko - (c) 1996-2009 the VideoLAN team
[00000001] main libvlc debug: libvlc was configured with ./configure ‘–build=i486-linux-gnu’ ‘–enable-maintainer-mode’ ‘–enable-release’ ‘–prefix=/usr’ ‘–enable-libtool’ ‘–enable-fast-install’ ‘–with-binary-version=2ubuntu1’ ‘–disable-update-check’ ‘–disable-gnome’ ‘–disable-gtk’ ‘–disable-familiar’ ‘–disable-fb’ ‘–enable-ggi’ ‘–enable-sdl’ ‘–enable-esd’ ‘–enable-mad’ ‘–enable-jack’ ‘–enable-pulse’ ‘–enable-lirc’ ‘–enable-a52’ ‘–enable-aa’ ‘–enable-dvbpsi’ ‘–enable-mozilla’ ‘–with-mozilla-pkg=libxul-plugin’ ‘–disable-kde’ ‘–enable-mp4’ ‘–enable-dvb’ ‘–disable-satellite’ ‘–enable-ogg’ ‘–enable-vorbis’ ‘–enable-shout’ ‘–enable-qt4’ ‘–disable-slp’ ‘–enable-flac’ ‘–disable-skins’ ‘–disable-basic-skins’ ‘–enable-skins2’ ‘–enable-freetype’ ‘–enable-mkv’ ‘–enable-speex’ ‘–enable-caca’ ‘–enable-live555’ ‘–enable-libmpeg2’ ‘–enable-fribidi’ ‘–enable-cdio’ ‘–enable-mod’ ‘–enable-theora’ ‘–enable-modplug’ ‘–enable-dvdnav’ ‘–enable-gnutls’ ‘–enable-ffmpeg’ ‘–enable-ncurses’ ‘–enable-smb’ ‘–disable-gnomevfs’ ‘–enable-bonjour’ ‘–enable-mpc’ ‘–enable-vcd’ ‘–enable-vcdx’ ‘–enable-notify’ ‘–enable-twolame’ ‘–enable-faad’ ‘–disable-zvbi’ ‘–enable-telx’ ‘–enable-mediacontrol-bindings’ ‘–disable-atmo’ ‘–enable-taglib’ ‘–enable-libass’ ‘–enable-libdca’ ‘–enable-realrtsp’ ‘–disable-dv’ ‘–enable-x264’ ‘–enable-alsa’ ‘–enable-v4l’ ‘–enable-v4l2’ ‘–enable-pvr’ ‘–enable-svgalib’ ‘–enable-dvd’ ‘–without-dvdcss’ ‘build_alias=i486-linux-gnu’ ‘CFLAGS=-g -O2’ ‘LDFLAGS=-Wl,–as-needed’ ‘CPPFLAGS=’ ‘CXXFLAGS=-g -O2’
[00000001] main libvlc debug: translation test: code is "ko"
[00000001] main libvlc: Running vlc with the default interface. Use ‘cvlc’ to use vlc without interface.
라고 나오네요
터미널에서 실행한 VLC 플레이어가 꺼지고 난 뒤에 남은 로그가 그것 뿐인 건가요? 로그상으로 보면 아무런 문제가 없는 것 처럼 보이는군요.
노틸러스에서 더블클릭을 여러번 하면 vlc가 2~3개 뜨는데
첫번째는 꺼지고 두번째나 세번째 뜨는 vlc에서는 재생이 되네요.
지금은 그렇게 쓰고 있는데, 자주 끊기기도 하고(윈도우 보다)…
1000h 쓰고 있고요. 그래픽카드는 GMA950으로 알고 있습니다.
그래픽카드 관련 문제인가요? 아니면 코덱 문제일까요?
vlc, mplayer, totem 모두 다 그러는 것으로 봐서 플레이어 문제는 아닌것 같고요.
화면 녹화 하는 프로그램이 어떤건가요?
있으면 녹화해서 올릴게요
영상 출력을 바꿔보세요.
xv, gl, gl2, x11등 여러가지가 있습니다.
인텔 내장이라면 영상 가속이 좀 딸릴것이라고 생각되니 일단 그래픽드라이버부터 어떻게 해봐야합니다.
혹시나 해서 ubuntu-netbook-remix 패키지를 깔았더니
그래픽드라이버가 잡혔나 봅니다. 지금은 잘되네요.
댓글 감사합니다.
