심플스캔과
xsane로 시도를 해보았습니다.
sane-find-scanner will now attempt to detect your scanner. If the
result is different from what you expected, first make sure your
scanner is powered up and properly connected to your computer.
No SCSI scanners found. If you expected something different, make sure that
you have loaded a kernel SCSI driver for your SCSI adapter.
found USB scanner (vendor=0x0461 [Primax], product=0x038c [USB Scanner], chip=GL646_HP) at libusb:003:006
Your USB scanner was (probably) detected. It may or may not be supported by
SANE. Try scanimage -L and read the backend’s manpage.
Not checking for parallel port scanners.
[/code]
Most Scanners connected to the parallel port or other proprietary ports
can’t be detected by this program.
찾긴 하는대 어떻게 스캔은 하지 못하네요 ㅠㅠ 도움 부탁드립니다.
[code:1ttyahnz]found USB scanner (vendor=0x0461, product=0x038c, chip=GL646_HP?) at libusb:003:006
<device descriptor of 0x1d6b/0x0001 at 003:001>
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1D6B
idProduct 0x0001
bcdDevice 2.06
iManufacturer 3 ()
iProduct 2 ()
iSerialNumber 1 ()
bNumConfigurations 1
<configuration 0>
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0 ()
bmAttributes 224 (Self-poweredRemote Wakeup)
MaxPower 0 mA
<interface 0>
<altsetting 0>
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0 ()
<endpoint 0>
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 (in 0x01)
bmAttributes 3 (interrupt)
wMaxPacketSize 2
bInterval 255 ms
bRefresh 0
bSynchAddress 0
<device descriptor of 0x1d6b/0x0001 at 002:001>
bLength 18
bDescriptorType 1
bcdUSB 1.10
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1D6B
idProduct 0x0001
bcdDevice 2.06
iManufacturer 3 ()
iProduct 2 ()
iSerialNumber 1 ()
<configuration 0>
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0 ()
MaxPower 0 mA
<interface 0>
<altsetting 0>
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
iInterface 0 ()
<endpoint 0>
bLength 7
bDescriptorType 5
wMaxPacketSize 2
bInterval 255 ms
bRefresh 0
bSynchAddress 0
<device descriptor of 0x1d6b/0x0002 at 001:001>
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 9
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1D6B
idProduct 0x0002
bcdDevice 2.06
iManufacturer 3 ()
iProduct 2 ()
iSerialNumber 1 ()
<configuration 0>
bLength 9
bDescriptorType 2
wTotalLength 25
bNumInterfaces 1
iConfiguration 0 ()
MaxPower 0 mA
<interface 0>
<altsetting 0>
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 9
iInterface 0 ()
<endpoint 0>
bLength 7
bDescriptorType 5
wMaxPacketSize 4
bInterval 12 ms
bRefresh 0
bSynchAddress 0
You may want to run this program as root to find all devices. Once you
found the scanner devices, be sure to adjust access permissions as
necessary.
[/code:1ttyahnz]
