ATI Radeon Catalyst 설치후
fglrxinfo open gl 이 잘 잡히지도 않고 이상한 에러 넘버만 뜹니다.
unity 는 실행 되지 않아서 부팅하면 바탕화면만 덩그러니 …
switchable graphic driver 라서 검색해서 여러 방법을 찾아 보고 따라 해봤는데
aticonfig 그리고 그래픽 카드 스위칭 하는것 자체가 작동이안됩니다
lspci 치면 amd 그래픽 카드를 vga 로 인식을 안합니다.
대략 이런 내용이 나옵니다.
00:00.0 Host bridge: Intel Corporation 3rd Gen Core processor DRAM Controller (rev 09)
Subsystem: Samsung Electronics Co Ltd Device c706
00:01.0 PCI bridge: Intel Corporation Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port (rev 09)
Kernel driver in use: pcieport
00:02.0 VGA compatible controller: Intel Corporation 3rd Gen Core processor Graphics Controller (rev 09)
Kernel driver in use: i915
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
Kernel driver in use: xhci_hcd
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
Kernel driver in use: mei
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
Kernel driver in use: ehci-pci
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
Kernel driver in use: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.3 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 4 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM76 Express Chipset LPC Controller (rev 04)
Kernel driver in use: lpc_ich
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
Kernel driver in use: ahci
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
01:00.0 Display controller: Advanced Micro Devices [AMD] nee ATI Mars [Radeon HD 8670A/8750M]
02:00.0 Network controller: Atheros Communications Inc. AR9485 Wireless Network Adapter (rev 01)
Subsystem: Samsung Electronics Co Ltd Device 4105
Kernel driver in use: ath9k
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168 PCI Express Gigabit Ethernet controller (rev 06)
Kernel driver in use: r8169
display controller 로 인식되어잇는 amd 그래픽 카드를 vga 로 인식 가능 하게 하면
카탈리스트 설치를 제대로 할수 있을것 같은데 전혀 방법이 없는것 일까요 ?
혹시 커널업그레이드후 이런상황인가요?
그렇다면, catalyst 다시 설치하세요
그리고, 바탕화면만 나오는 사태는
viewtopic.php?f=22&t=24725&p=113270&hilit=ccsm#p113270
이 글을 참조하시고요.
그리고, 커널이 업데이트가 되면 이걸 다시 해줘야 합니다.
glrxinfo 나 fglrxinfo 치면 opengl 항목 자체에 에러 코드가 떠서요 아무래도 비디오 카드가 제대로 설치가 되지 않아서 그런것 같네요… 근데 이상한게 어제 페도라를 깔아서 같은 비디오 카드를 설치하니까 비디오 카드가 잡히러더라구요 페도라 커널이 3.10 이여서 커널 문제인가 하고 우분투를 다시깔고 커널 업데이트를 한다음에 비디오 카드 드라이버 설치하려고 하니까 같은 문제가 발생하네요… 근데 또 페도라로 다시 잡아 보려니까 안되구요… 하아 … ㅠㅠ amd 의 리눅스 지원이 거의 암흑이라던데… 그래서 그런건지 답도 안나오네요
amd 들어가서 비디오카드를 찾아보세요…
사양을 선택하면 지원하는지 아닌지 알수 있고요.
어떤거는 옛날버전의 catalyst를 사용해야 될때도 있더라구요 지원되기 전에는…
예전에 한 번 그런적이 있었어요…
한번 더 찾아보심이…
지원 목록에는 분명히 해당하는데 말이죠 …
근데 공공히 생각해보니 윈도우에서 카탈리스트 드라이버 문제 때문에 업데이트 못하고 삼성에서 업데이트 해준 드라이버만 설치 했던 경우가 있네요
삼성 웹에서 제공해준 드라이버 카탈리스트 버전확인해보고 다시 포스트 해보겠습니다.
문제 해결 법을 찾았습니다.
터미널에서 echo ON > /sys/kernel/debug/vgaswitcheroo/switch
치고 난뒤에 카탈리스트 드라이버 설치 시도 하면 문제 없이 되네요 .
