Backtrack N150UA드라이버 설치오류ㅠㅠㅠ
제가 못하는건지… 인터넷 따라서 설치했는데도 안되네요 ㅠㅠ
OS : Backtrack5 r3
Kernel : 3.2.6
iptime N150UA solo
iptime에서 리눅스용 드라이버 다운받아서 설치했는데 안되네요 ㅠ
몇번쨰 갈아엎고 그러는건지… 도와주세요 ㅠㅠ
[code:1qc0ewao]
root@bt:~/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913# make
make -C tools
make[1]: Entering directory /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/tools' gcc -g bin2h.c -o bin2h make[1]: Leaving directory /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/tools’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/tools/bin2h
cp -f os/linux/Makefile.6 /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/Makefile
make -C /lib/modules/3.2.6/build SUBDIRS=/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux modules
make[1]: Entering directory `/usr/src/linux-source-3.2.6’
WARNING: Symbol version dump /usr/src/linux-source-3.2.6/Module.symvers
is missing; modules will have no dependencies and modversions.
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_profile.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_profile.c: In function ‘announce_802_3_packet’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_profile.c:331: warning: unused variable ‘pAd’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_profile.c: In function ‘STA_MonPktSend’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_profile.c:399: warning: format ‘%d’ expects type ‘int’, but argument 3 has type ‘long unsigned int’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/assoc.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/auth.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/auth_rsp.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/sync.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/sync.c: In function ‘PeerBeacon’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/sync.c:2181: warning: passing argument 8 of ‘StaAddMacTableEntry’ from incompatible pointer type
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/include/rtmp.h:7892: note: expected ‘struct IE_LISTS *’ but argument is of type ‘struct BCN_IE_LIST *’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/sanity.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/rtmp_data.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/rtmp_data.c: In function ‘STAHandleRxDataFrame’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/rtmp_data.c:523: warning: passing argument 2 of ‘MacTableLookup’ from incompatible pointer type
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/include/rtmp.h:8429: note: expected ‘UCHAR ’ but argument is of type ‘UCHAR ()[6]’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/connect.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/wpa.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/sta_cfg.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/sta_cfg.c: In function ‘RTMPIoctlRF’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/sta_cfg.c:5306: warning: format ‘%02X’ expects type ‘unsigned int’, but argument 5 has type ‘LONG’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/sta_cfg.c:5359: warning: passing argument 2 of ‘RtmpDrvAllRFPrint’ from incompatible pointer type
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/include/rt_os_util.h:668: note: expected ‘UINT32 *’ but argument is of type ‘PSTRING’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/sta_cfg.c:5209: warning: unused variable ‘rf_bank’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/sta_cfg.c: In function ‘RtmpIoctl_rt_ioctl_siwgenie’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../sta/sta_cfg.c:7610: warning: assignment from incompatible pointer type
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/crypt_md5.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/crypt_sha2.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/crypt_hmac.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/crypt_aes.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/crypt_aes.c: In function ‘AES_Key_Wrap’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/crypt_aes.c:1459: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘long unsigned int’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/crypt_aes.c: In function ‘AES_Key_Unwrap’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/crypt_aes.c:1554: warning: format ‘%d’ expects type ‘int’, but argument 2 has type ‘long unsigned int’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/crypt_arc4.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/mlme.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/mlme.c: In function ‘MlmeResetRalinkCounters’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/mlme.c:543: warning: cast from pointer to integer of different size
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/mlme.c: In function ‘AsicRxAntEvalTimeout’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/mlme.c:5201: warning: unused variable ‘rssi_diff’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_wep.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/action.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_data.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_data.c: In function ‘CmdRspEventCallbackHandle’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_data.c:2509: warning: unused variable ‘Ret’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_data.c: In function ‘StopDmaTx’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_data.c:2684: warning: unused variable ‘IdleNums’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_data.c:2682: warning: unused variable ‘UsbCfg’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtmp_init.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtmp_init.c: In function ‘NICInitAsicFromEEPROM’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtmp_init.c:981: warning: unused variable ‘i’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtmp_init.c: In function ‘NICInitializeAdapter’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtmp_init.c:1292: warning: unused variable ‘GloCfg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtmp_init.c: In function ‘NICInitializeAsic’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtmp_init.c:1367: warning: unused variable ‘KeyIdx’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtmp_init.c:1656: warning: the frame size of 1040 bytes is larger than 1024 bytes
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtmp_init_inf.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_tkip.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_aes.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_sync.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/eeprom.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/eeprom.c: In function ‘RtmpChipOpsEepromHook’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/eeprom.c:34: warning: unused variable ‘e2p_csr’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_sanity.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_info.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_info.c: In function ‘Set_DebugFunc_Proc’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_info.c:1084: warning: format ‘%x’ expects type ‘unsigned int’, but argument 2 has type ‘const char *’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_info.c:1084: warning: too many arguments for format
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_info.c: In function ‘set_rf’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_info.c:5730: warning: format ‘%x’ expects type ‘unsigned int *’, but argument 5 has type ‘UCHAR *’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_cfg.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_cfg.c: In function ‘wmode_valid_and_correct’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_cfg.c:279: warning: unused variable ‘mode’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_cfg.c: At top level:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_cfg.c:264: warning: ‘wmode_valid’ defined but not used
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_wpa.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_radar.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/spectrum.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/spectrum.c: In function ‘PeerMeasureReportAction’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/spectrum.c:1972: warning: format ‘%d’ expects type ‘int’, but argument 3 has type ‘long unsigned int’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtmp_timer.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rt_channel.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_profile.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_profile.c: In function ‘rtmp_read_multest_from_file’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_profile.c:2671: warning: unused variable ‘pWdsEntry’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_asic.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/scan.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_cmd.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/uapsd.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/ps.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../rate_ctrl/ra_ctrl.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../rate_ctrl/alg_legacy.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../rate_ctrl/alg_ags.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/rtmp_chip.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/txpower.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mac/rtmp_mac.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mgmt/mgmt_hw.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mgmt/mgmt_entrytb.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../phy/rtmp_phy.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../phy/rtmp_phy.c: In function ‘NICInitBBP’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../phy/rtmp_phy.c:61: warning: unused variable ‘R0’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../phy/rlt_phy.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../phy/rlt_rf.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/ba_action.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/ba_action.c: In function ‘convert_reordering_packet_to_preAMSDU_or_802_3_packet’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/ba_action.c:1574: warning: assignment makes integer from pointer without a cast
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mgmt/mgmt_ht.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rt_os_util.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/sta_ioctl.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c: In function ‘RtmpOsUsDelay’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c:179: warning: unused variable ‘i’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c: In function ‘duplicate_pkt’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c:497: warning: passing argument 1 of ‘memmove’ makes pointer from integer without a cast
/usr/src/linux-source-3.2.6/arch/x86/include/asm/string_64.h:58: note: expected ‘void *’ but argument is of type ‘sk_buff_data_t’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c:499: warning: passing argument 1 of ‘memmove’ makes pointer from integer without a cast
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c: In function ‘ClonePacket’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c:650: warning: assignment makes integer from pointer without a cast
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c: In function ‘RtmpOsPktInit’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c:669: warning: assignment makes integer from pointer without a cast
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c: In function ‘wlan_802_11_to_802_3_packet’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c:695: warning: assignment makes integer from pointer without a cast
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c: In function ‘RtmpDrvAllRFPrint’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c:2052: warning: passing argument 2 of ‘file_w->f_op->write’ from incompatible pointer type
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c:2052: note: expected ‘const char *’ but argument is of type ‘UINT32 *’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c:2037: warning: unused variable ‘macValue’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c:2037: warning: unused variable ‘macAddr’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c: In function ‘RtmpOSIRQRelease’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_linux.c:2173: warning: unused variable ‘net_dev’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_main_dev.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_mac_usb.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_mac_usb.c: In function ‘RTMPAllocTxRxRingMemory’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_mac_usb.c:562: warning: initialization from incompatible pointer type
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_mac_usb.c: In function ‘RT28XXDMAEnable’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_mac_usb.c:1371: warning: unused variable ‘UsbCfg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_mac_usb.c:1370: warning: unused variable ‘GloCfg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_mac_usb.c: In function ‘RT28xxUsbAsicRadioOn’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_mac_usb.c:1931: warning: unused variable ‘GloCfg’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_data_usb.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_data_usb.c: In function ‘ComposeNullFrame’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_data_usb.c:279: warning: ISO C90 forbids mixed declarations and code
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_data_usb.c: At top level:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/cmm_data_usb.c:222: warning: ‘rlt_usb_update_txinfo’ defined but not used
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtusb_io.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtusb_io.c: In function ‘RTUSBWriteEEPROM’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtusb_io.c:682: warning: unused variable ‘Value’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtusb_data.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtusb_bulk.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtusb_bulk.c: In function ‘RTUSBCancelPendingBulkOutIRP’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtusb_bulk.c:1678: warning: assignment from incompatible pointer type
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_usb.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_usb.c: In function ‘cmd_rsp_event_tasklet’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_usb.c:537: warning: assignment from incompatible pointer type
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/ee_prom.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/ee_efuse.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c: In function ‘USBLoadIVB’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c:68: warning: unused variable ‘Temp’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c:67: warning: unused variable ‘Index’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c:66: warning: unused variable ‘Value’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c:65: warning: unused variable ‘i’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c: In function ‘USBLoadFirmwareToAndes’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c:105: warning: unused variable ‘MCtrl’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c:104: warning: unused variable ‘UsbCfg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c: In function ‘MCUCtrlExit’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c:591: warning: unused variable ‘Ret’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c: In function ‘GetCmdRspNum’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c:634: warning: unused variable ‘IrqFlags’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c: In function ‘AndesLedOP’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_and.c:2071: warning: unused variable ‘Value’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_mcu.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_mcu.c: In function ‘MCUBurstWrite’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_mcu.c:32: warning: passing argument 3 of ‘RTUSBMultiWrite_nBytes’ from incompatible pointer type
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/include/rtmp.h:7553: note: expected ‘PUCHAR’ but argument is of type ‘UINT32 *’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_mcu.c: In function ‘ChipOpsMCUHook’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_mcu.c:64: warning: assignment from incompatible pointer type
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_mcu.c:71: warning: assignment from incompatible pointer type
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_mcu.c:72: warning: assignment from incompatible pointer type
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_mcu.c: In function ‘MCURandomWrite’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_mcu.c:41: warning: control reaches end of non-void function
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_mcu.c:33: warning: control reaches end of non-void function
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mcu/rtmp_M51.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rt_rf.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601_INIT_CAL’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:888: warning: unused variable ‘Temperature’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘NICInitMT7601RFRegisters’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:1006: warning: unused variable ‘IdReg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘NICInitMT7601MacRegisters’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:1044: warning: unused variable ‘IdReg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘NICInitMT7601BbpRegisters’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:1086: warning: unused variable ‘IdReg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601_ChipSwitchChannel’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:1442: warning: ISO C90 forbids mixed declarations and code
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:1272: warning: unused variable ‘IdReg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601DisableTxRx’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:1497: warning: ‘return’ with no value, in function returning non-void
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601UsbAsicRadioOff’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:1725: warning: unused variable ‘Value’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601UsbAsicRadioOn’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:1790: warning: unused variable ‘pChipOps’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:1789: warning: unused variable ‘GloCfg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601_ReadChannelPwr’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:1905: warning: unused variable ‘bUseDefault’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601AsicTemperatureCompensation’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:2282: warning: unused variable ‘IdReg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601_EnableTSSI’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:2478: warning: unused variable ‘ret’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:2477: warning: unused variable ‘BBPReg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:2477: warning: unused variable ‘RFReg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601_InitDesiredTSSITable’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:2611: warning: unused variable ‘offset’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:2611: warning: unused variable ‘index’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601_GetTssiCompensationParam’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:2682: warning: unused variable ‘ret’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:2681: warning: unused variable ‘count’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:2675: warning: unused variable ‘RFReg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601_AsicTxAlcGetAutoAgcOffset’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:2949: warning: unused variable ‘BBPReg’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c: In function ‘MT7601_Init’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../chips/mt7601.c:3399: warning: assignment from incompatible pointer type
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../mac/ral_omac.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_usb_util.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_usb_util.c: In function ‘rausb_autopm_put_interface’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_usb_util.c:120: warning: unused variable ‘pm_usage_cnt’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_usb_util.c: In function ‘rausb_autopm_get_interface’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_usb_util.c:151: warning: unused variable ‘pm_usage_cnt’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/rt_usb_util.c:157: warning: control reaches end of non-void function
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/usb_main_dev.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/usb_main_dev.c: In function ‘rt2870_suspend’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/usb_main_dev.c:394: warning: unused variable ‘net_dev’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/usb_main_dev.c: In function ‘rt2870_resume’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../os/linux/usb_main_dev.c:450: warning: unused variable ‘net_dev’
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/rtusb_dev_id.o
CC [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/frq_cal.o
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/frq_cal.c: In function ‘InitFrequencyCalibration’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/frq_cal.c:88: warning: format ‘%x’ expects type ‘unsigned int’, but argument 4 has type ‘ULONG’
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/frq_cal.c: In function ‘FrequencyCalibrationMode’:
/root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/../../common/frq_cal.c:130: warning: unused variable ‘PreRFValue’
LD [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/mt7601Usta.o
Building modules, stage 2.
MODPOST 1 modules
CC /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/mt7601Usta.mod.o
LD [M] /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/mt7601Usta.ko
make[1]: Leaving directory `/usr/src/lsinux-source-3.2.6’
cp -f /root/Desktop/DPO_MT7601U_LinuxSTA_3.0.0.4_20130913/os/linux/mt7601Usta.ko /tftpboot 2>/dev/null ||
[/code:1qc0ewao]
하하하 아니에요
공부하는거라서…ㅎ
