예전에 보았을 때에는 작동도 좀 이상했고, 업데이트도 느린 듯 했는데, 그간 새로운 버젼을 작업하고 있었던 모양입니다.
인터페이스는 Adobe Premier와 비슷한 것 같습니다. 리눅스에서 고급 영상 편집에 사용할 수 있는 유일한 어플리케이션이 아닐지…
[url:17842lz5]http://cinelerra.org/[/url:17842lz5]
PPA 추가 및 설치는 여기> [url:17842lz5]https://launchpad.net/~cinelerra-ppa/+archive/ppa[/url:17842lz5]
아래는 릴리즈에 관한 영문 설명입니다.
[quote:17842lz5]After more than four years of rather silent work on Cinelerra 2.1CV we are now
pleased to officially announce the release of Cinelerra 2.1.5CV!
During the last eight months more than twenty patches were contributed and
finally merged. They are available using ‘git clone’ or ‘git pull’ from:
To make these changes obvious to everyone we decided to increase the version
number to 2.1.5CV.
Recent changes (since 2010) are:
SWOT audio is now supported.
Build fixes for newer environments (libpng 1.4.3, libjpeg 7, and others).
PNG with more than 8 bits can be imported, the extra precision is truncated,
though. -
The YUV4MPEG importer is now much more efficient.
Correct latency calculation with OSS audio driver.
And assorted other fixes, many of them taken from Gentoo and Achlinux. See
the short-log for details.
For users, Cinelerra 2.1.5CV stands for the best editing experience so far.
For developers, contributors, and distributors, the release of Cinelerra
2.1.5CV is meant to be a crystal clear signal that the community version of
Cinelerra is still actively developed, even though progress might appear to
be somewhat slow due to the current lack of manpower. (You are invited to
change that!)
In this context we would like to refer to bugs.cinelerra.org: Please help by
supplying comprehensive bug reports, and of course by sending in patches for
the next release, Cinelerra 2.1.6CV.
In case you are missing a patch that has been already sent in, it is likely to
have slid into obscurity, thus please feel free to remind us!
With best regards,
Your CinelerraCV developers
Recent changes by contributor:
Einar Rünkaru (8):
Updated .gitignore files with names of generated files
Fix mmap errorcode
Fixed compilation on Fedora 13
Fix compilation error in edits.C.
Check OpenGL server version at runtime.
Initialized edit_font_color in S.U.V theme
Fix videos with row length not multiple of 16
Change return type of Thread:get_tid()
Mark Goldberg (1):
Add SWOT audio support, slightly modified from twos.c and
twos.h.
Monty (8):
Change wording of the option that disables hardware
synchronization.
Correct a calling error of sws_scale().
Add return code checking to ALSA backend.
Add [trivial] support for all non-8-bit-RGB png types in the
VFrame abstraction.
Fix build with libx264 version 76 and later.
Fix OSS latency calculation.
Check error codes in OSS audio driver.
Eliminate useless indexes from YUV4MPEG2 file loader.
Simeon Voelkel (7):
make shapewipe compile using libpng1.4.3
fix compilation problem on gentoo due to nasm script
apply gentoo pkgconfig x264 patch to configure.in
fix background rendering crash on >=jpeg-7 (patch adopted from
gentoo)
Do not use outdated pixel format names in ffmpeg code.
Correct a rounding bug in the compositor fade engine.
Move Cinelerra to version 2.1.5CV
Cinelerra mailing list
Cinelerra@skolelinux.no https://init.linpro.no/mailman/skolelin ... /cinelerra[/quote:17842lz5]
