우분투 10.04 버전을 쓰고 있는데요.
djbdns를 깔아보려고 이래저래 삽질에 삽질을 거듭하고 있는데요.
현재 막히는 부분이
[code:56jpwskf]
svc -t /service/dnscache
svc: warning: unable to control /service/dnscache: file does not exist
[/code:56jpwskf]
이렇게 실행하면 파일이없다고 나옵니다. 한참 구글링을 해서 로그를 찍어본결과
[code:56jpwskf]
strace svc -t /service/dnscache
execve("/usr/bin/svc", ["svc", "-t", "/service/dnscache"], [/* 19 vars */]) = 0
brk(0) = 0x16b0000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7ff927e56000
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=23782, ...}) = 0
mmap(NULL, 23782, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7ff927e50000
close(3) = 0
open("/lib/libc.so.6", O_RDONLY) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`\355\1\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1572232, ...}) = 0
mmap(NULL, 3680296, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7ff9278b6000
mprotect(0x7ff927a30000, 2093056, PROT_NONE) = 0
mmap(0x7ff927c2f000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x179000) = 0x7ff927c2f000
mmap(0x7ff927c34000, 18472, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7ff927c34000
close(3) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7ff927e4f000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7ff927e4e000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7ff927e4d000
arch_prctl(ARCH_SET_FS, 0x7ff927e4e700) = 0
mprotect(0x7ff927c2f000, 16384, PROT_READ) = 0
mprotect(0x602000, 4096, PROT_READ) = 0
mprotect(0x7ff927e58000, 4096, PROT_READ) = 0
munmap(0x7ff927e50000, 23782) = 0
rt_sigaction(SIGPIPE, {SIG_IGN, , SA_RESTORER, 0x7ff9278e9af0}, NULL, 8) = 0
open(".", O_RDONLY|O_NONBLOCK) = 3
chdir("/service/dnscache") = 0
open("supervise/control", O_WRONLY|O_NONBLOCK) = -1 ENOENT (No such file or directory)
write(2, "svc: warning: unable to control "..., 71svc: warning: unable to control /service/dnscache: file does not exist
) = 71
fchdir(3) = 0
exit_group(0) = ?
[/code:56jpwskf]
이렇게 나온거보면 /service/dnscache/폴더에 supervise/control 파일을 실행 시킬려고 하는것같은데..
[code:56jpwskf]
ls -al
total 28
drwxr-sr-t 5 root root 4096 2011-05-22 22:40 .
drwxr-xr-x 94 root root 4096 2011-05-22 22:38 ..
drwxr-sr-x 2 root root 4096 2011-05-22 21:52 env
drwxr-sr-x 3 root root 4096 2011-05-22 22:19 log
drwxr-sr-x 4 root root 4096 2011-05-22 21:52 root
-rwxr-xr-x 1 root root 135 2011-05-22 21:52 run
-rw------- 1 root root 128 2011-05-22 21:52 seed
[/code:56jpwskf]
그런 폴더는 없고 실행파일은 run 만 있네요. run이 실행되어야하는것같은데… contorl이라는 파일을 찾는것같은데.. 혹시 이부분에 대해서 아시는분은 답변좀 부탁드립니다.
