Eeepc 1000h 유무선랜 잡는 방법 알려주세요. 인터넷 안될때 NDISwrapper 어떻게 설치하나요?
00:00.0 Host bridge: Intel Corporation Mobile 945GME Express Memory Controller Hub (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Mobile 945GME Express Integrated Graphics Controller (rev 03)
00:02.1 Display controller: Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller (rev 03)
00:1b.0 Audio device: Intel Corporation 82801G (ICH7 Family) High Definition Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 1 (rev 02)
00:1c.1 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 2 (rev 02)
00:1c.3 PCI bridge: Intel Corporation 82801G (ICH7 Family) PCI Express Port 4 (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #3 (rev 02)
00:1d.3 USB Controller: Intel Corporation 82801G (ICH7 Family) USB UHCI Controller #4 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801G (ICH7 Family) USB2 EHCI Controller (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev e2)
00:1f.0 ISA bridge: Intel Corporation 82801GBM (ICH7-M) LPC Interface Bridge (rev 02)
00:1f.2 IDE interface: Intel Corporation 82801GBM/GHM (ICH7 Family) SATA IDE Controller (rev 02)
01:00.0 Network controller: RaLink Unknown device 0781
03:00.0 Ethernet controller: Attansic Technology Corp. Unknown device 1026 (rev b0)
다른글 보니까 루트에서 lspci 명령어로 랜카드 정보 올리면 쉽게 도움받을수 있을거라고 하셔서 올립니다.
윈도우 xp용 무선랜 드라이버는 아수스 홈페이지에서 다운 받았고 데탑에 설치하니까 RaLink라는 폴더에 저장되는 걸로
봐서는 밑에서 두번째 줄이 무선랜같은데요… 마지막줄은 유선랜 같고,
검색하다가 NDISwrapper로 한다는것 까지는 찾았는데 (ralink 무선랜은 리눅스용 드라이버 없나봐요,)
인터넷이 안되니까 NDISwrapper 패키지 설치도 못하고 있습니다.
[quote="noblesse":2nz1cdde]00:00.0 Host bridge: Intel Corporation Mobile 945GME Express Memory Controller Hub (rev 03)
인터넷이 안되니까 NDISwrapper 패키지 설치도 못하고 있습니다.[/quote:2nz1cdde]
해외의 eee pc 우분투 사용자 모임의 글입니다. 순서대로만 하시면 별탈없이 설치되더군요.
Wireless internet using ndiswrapper
Atheros has released a patch to use native madwifi drivers on the EEE. That would be the preferable solution (see above) as ndiswrapper has some performance issues on the EEE. Several people report increased cpu utilization by the driver and of course it has all of the limitiations of ndiswrapper. It would be advisable to use the above directions for installing a patched madwifi driver. These directions are here should that not be possible. Be sure to install the wpasupplicant package if you need WPA security.
  Alternate instructions on a separate wikipage: Make WiFi work through ndiswrapper if you changed Linux distro
  This console method is a surefire way to get wireless working, as ndisgtk does not appear to install the driver correctly
  Remove ath_pci module so it doesn't conflict with anything
sudo modprobe -r ath_pci
  Edit /etc/modprobe.d/blacklist-common
sudo gedit /etc/modprobe.d/blacklist-common
  Add the following line to prevent ath_pci from loading
blacklist ath_pci
  Reboot for good measure
  Install the ndiswrapper packages
sudo apt-get install ndiswrapper-common ndiswrapper-utils-1.9
  Retrieve the drivers from the support DVD and transfer them over via USB, or download them from the Asus Site (Here)
  Look for the “ndis5x” folder, extract it to a safe location.
  Navigate to the location in the terminal, and install the driver
sudo ndiswrapper -i net5211.inf
  Modprobe the driver
sudo ndiswrapper -m
  Finalize the installation (I found this was necessary for it to work)
sudo ndiswrapper -ma && sudo ndiswrapper -mi
  Reboot, and voilà! Use the already installed network software to configure your network settings.
