G15daemon, g15macro, g15stats 에러 메세지 관련 질문
g15daemon에 대하여 아래와 같은 에러메세지가 뜨는데, 이건 ubuntu error인가요? 아님 bug인가요?
Error라면 어떻게 처리할 수 있나요?
ygchai@ygchai-home:~$ sudo apt-get install vim
[sudo] password for ygchai:
Reading package lists… Done
Building dependency tree
Reading state information… Done
vim is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
3 not fully installed or removed.
After this operation, 0B of additional disk space will be used.
Setting up g15daemon (1.9.5.3-3) …
Starting g15daemon: invoke-rc.d: initscript g15daemon, action "start" failed.
dpkg: error processing g15daemon (–configure):
subprocess post-installation script returned error exit status 1
dpkg: dependency problems prevent configuration of g15macro:
g15macro depends on g15daemon; however:
Package g15daemon is not configured yet.
dpkg: error processing g15macro (–configure):
dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of g15stats:
g15stats depends on g15daemon; however:
dpkg: error processing g15stats (–configure):
No apport report written because the error message indicates its a followup error from a previous failure.
Errors were encountered while processing:
g15daemon
g15macro
g15stats
E: Sub-process /usr/bin/dpkg returned an error code (1)
g15면 로지텍 관련 데몬 같은데…
설정을 해줘야 하는거 아닌지요
sudo g15daemon 또는
sudo g15daemon --configure
sudo g15macro --configure
sudo g15daemon을 terminal에서 넣으면 아무런 반응이 없습니다.
주로 sudo apt-get install 할 때 혹은 remove 할 때 보이는데…, bug라고 생각하는 점은 그래도 installing이나 removing에 아무런 영향이 없기 때문입니다. 계속 에러 메세지가 보여서… 혹시 처리를 해 줘야 하나 궁금하여 문의 드렸습니다.
