Hardy에서 Xorg관련 바뀐 부분있나요?
안녕하세요? Hardy에서 그래픽카드 관련 설정을 하다가 궁금한게 있어서 질문드립니다.
일단, 제 xorg.conf를 첨부합니다.
[code:3w276l2x]
Section "InputDevice"
Identifier "Generic Keyboard"
Driver "kbd"
Option "XkbRules" "xorg"
Option "XkbModel" "pc105"
Option "XkbLayout" "kr"
Option "XkbVariant" "kr104"
EndSection
Identifier "Configured Mouse"
Driver "mouse"
Option "CorePointer"
EndSection
Identifier "Synaptics Touchpad"
Driver "synaptics"
Option "SendCoreEvents" "true"
Option "Device" "/dev/psaux"
Option "Protocol" "auto-dev"
Option "HorizEdgeScroll" "0"
EndSection
Section "Device"
Identifier "Configured Video Device"
EndSection
Section "Monitor"
Identifier "Configured Monitor"
EndSection
Section "Screen"
Identifier "Default Screen"
Monitor "Configured Monitor"
Device "Configured Video Device"
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Synaptics Touchpad"
EndSection
[/code:3w276l2x]
굉장히 짧습니다…;;;
문제는 여기다가 wacom 설정을 추가하기 위해 Section을 조금 추가하니 X가 안뜨네요.
또, Device부분에 보면 Driver 없이 Identifier만 존재합니다.
그래서 displayconfig-gtk를 실행해도 카드가 None으로 나오고요
근데!!! Compiz나 해상도나 다 정상 작동합니다. ^^;;;;
무엇이 문제일까요? Hardy 쓰시는 분들 다 저렇게 되어있나요?
참고사항으로 제 Xorg log를 답니다.
[code:3w276l2x]
(==) Log file: "/var/log/Xorg.0.log", Time: Thu May 29 18:59:37 2008
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Default Layout"
() |–>Screen "Default Screen" (0)
) | |–>Monitor "Configured Monitor"
() | |–>Device "Configured Video Device"
) |–>Input Device "Synaptics Touchpad"
(==) Automatically adding devices
(==) Automatically enabling devices
(==) No FontPath specified. Using compiled-in default.
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType
(==) RgbPath set to "/etc/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(==) |–>Input Device "Configured Mouse"
(==) |–>Input Device "Generic Keyboard"
(==) The core pointer device wasn’t specified explicitly in the layout.
Using the first core pointer device.
(==) The core keyboard device wasn’t specified explicitly in the layout.
Using the first keyboard device.
(II) Open ACPI successful (/var/run/acpid.socket)
(II) Loader magic: 0x81dc500
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 2.0
X.Org XInput driver : 2.0
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 1.4.0.90, module version = 1.0.0
ABI class: X.Org Video Driver, version 2.0
(++) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 8086,27a0 card 103c,30b1 rev 03 class 06,00,00 hdr 00
(II) PCI: 00:02:0: chip 8086,27a2 card 103c,30b1 rev 03 class 03,00,00 hdr 80
(II) PCI: 00:02:1: chip 8086,27a6 card 103c,30b1 rev 03 class 03,80,00 hdr 80
(II) PCI: 00:1b:0: chip 8086,27d8 card 103c,30b1 rev 01 class 04,03,00 hdr 00
(II) PCI: 00:1c:0: chip 8086,27d0 card 0000,0000 rev 01 class 06,04,00 hdr 81
(II) PCI: 00:1c:1: chip 8086,27d2 card 0000,0000 rev 01 class 06,04,00 hdr 81
(II) PCI: 00:1c:3: chip 8086,27d6 card 0000,0000 rev 01 class 06,04,00 hdr 81
(II) PCI: 00:1d:0: chip 8086,27c8 card 103c,30b1 rev 01 class 0c,03,00 hdr 80
(II) PCI: 00:1d:1: chip 8086,27c9 card 103c,30b1 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:1d:2: chip 8086,27ca card 103c,30b1 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:1d:3: chip 8086,27cb card 103c,30b1 rev 01 class 0c,03,00 hdr 00
(II) PCI: 00:1d:7: chip 8086,27cc card 103c,30b1 rev 01 class 0c,03,20 hdr 00
(II) PCI: 00:1e:0: chip 8086,2448 card 0000,0000 rev e1 class 06,04,01 hdr 01
(II) PCI: 00:1f:0: chip 8086,27b9 card 103c,30b1 rev 01 class 06,01,00 hdr 80
(II) PCI: 00:1f:1: chip 8086,27df card 103c,30b1 rev 01 class 01,01,8a hdr 00
(II) PCI: 00:1f:2: chip 8086,27c5 card 103c,30b1 rev 01 class 01,06,01 hdr 00
(II) PCI: 02:06:0: chip 104c,8039 card 1400,0000 rev 00 class 06,07,00 hdr 82
(II) PCI: 02:06:2: chip 104c,803b card 103c,30b1 rev 00 class 01,80,00 hdr 80
(II) PCI: 02:06:3: chip 104c,803c card 103c,30b1 rev 00 class 08,05,00 hdr 80
(II) PCI: 02:06:4: chip 104c,803d card 103c,30b1 rev 00 class 07,80,00 hdr 80
(II) PCI: 08:00:0: chip 14e4,16fd card 103c,30b1 rev 21 class 02,00,00 hdr 00
(II) PCI: 10:00:0: chip 8086,4222 card 103c,135d rev 02 class 02,80,00 hdr 00
(II) PCI: End of PCI scan
(II) Intel Bridge workaround enabled
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,32), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-PCI bridge:
(II) Bus 8: bridge is at (0:28:0), (0,8,8), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 8 non-prefetchable memory range:
[0] -1 0 0xf4100000 - 0xf41fffff (0x100000) MX[B]
(II) Bus 16: bridge is at (0:28:1), (0,16,16), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 16 non-prefetchable memory range:
[0] -1 0 0xf4000000 - 0xf40fffff (0x100000) MX[B]
(II) Bus 32: bridge is at (0:28:3), (0,32,32), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 32 I/O range:
[0] -1 0 0x00002000 - 0x000020ff (0x100) IX[B]
[1] -1 0 0x00002400 - 0x000024ff (0x100) IX[B]
[2] -1 0 0x00002800 - 0x000028ff (0x100) IX[B]
[3] -1 0 0x00002c00 - 0x00002cff (0x100) IX[B]
[4] -1 0 0x00003000 - 0x000030ff (0x100) IX[B]
[5] -1 0 0x00003400 - 0x000034ff (0x100) IX[B]
[6] -1 0 0x00003800 - 0x000038ff (0x100) IX[B]
[7] -1 0 0x00003c00 - 0x00003cff (0x100) IX[B]
(II) Bus 32 non-prefetchable memory range:
[0] -1 0 0xf0000000 - 0xf3ffffff (0x4000000) MX[B]
(II) Subtractive PCI-to-PCI bridge:
(II) Bus 2: bridge is at (0:30:0), (0,2,6), BCTRL: 0x0006 (VGA_EN is cleared)
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xf4200000 - 0xf45fffff (0x400000) MX[B]
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:31:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-CardBus bridge:
(II) Bus 3: bridge is at (2:6:0), (2,3,6), BCTRL: 0x05c0 (VGA_EN is cleared)
(–) PCI:*(0:2:0) Intel Corporation Mobile 945GM/GMS, 943/940GML Express Integrated Graphics Controller rev 3, Mem @ 0xf4600000/19, 0xe0000000/28, 0xf4680000/18, I/O @ 0x4000/3
(–) PCI: (0:2:1) Intel Corporation Mobile 945GM/GMS/GME, 943/940GML Express Integrated Graphics Controller rev 3, Mem @ 0xf4700000/19
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) Active PCI resource ranges:
[0] -1 0 0xf4000000 - 0xf4000fff (0x1000) MX[B]
[1] -1 0 0xf4100000 - 0xf410ffff (0x10000) MX[B]
[2] -1 0 0xf4204000 - 0xf4204fff (0x1000) MX[B]
[3] -1 0 0xf4203000 - 0xf4203fff (0x1000) MX[B]
[4] -1 0 0xf4202000 - 0xf42020ff (0x100) MX[B]
[5] -1 0 0xf4201000 - 0xf4201fff (0x1000) MX[B]
[6] -1 0 0xf4785000 - 0xf47853ff (0x400) MX[B]
[7] -1 0 0xf4784000 - 0xf47843ff (0x400) MX[B]
[8] -1 0 0xf4780000 - 0xf4783fff (0x4000) MX[B]
[9] -1 0 0xf4700000 - 0xf477ffff (0x80000) MX[B](B)
[10] -1 0 0xf4680000 - 0xf46bffff (0x40000) MX[B](B)
[11] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[12] -1 0 0xf4600000 - 0xf467ffff (0x80000) MX[B](B)
[13] -1 0 0x000040d0 - 0x000040df (0x10) IX[B]
[14] -1 0 0x00001574 - 0x00001577 (0x4) IX[B]
[15] -1 0 0x00001370 - 0x00001377 (0x8) IX[B]
[16] -1 0 0x000015f4 - 0x000015f7 (0x4) IX[B]
[17] -1 0 0x000013f0 - 0x000013f7 (0x8) IX[B]
[18] -1 0 0x000040a0 - 0x000040af (0x10) IX[B]
[19] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[20] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[21] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[22] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[23] -1 0 0x00004080 - 0x0000409f (0x20) IX[B]
[24] -1 0 0x00004060 - 0x0000407f (0x20) IX[B]
[25] -1 0 0x00004040 - 0x0000405f (0x20) IX[B]
[26] -1 0 0x00004020 - 0x0000403f (0x20) IX[B]
[27] -1 0 0x00004000 - 0x00004007 (0x8) IX[B](B)
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xf4000000 - 0xf4000fff (0x1000) MX[B]
[5] -1 0 0xf4100000 - 0xf410ffff (0x10000) MX[B]
[6] -1 0 0xf4204000 - 0xf4204fff (0x1000) MX[B]
[7] -1 0 0xf4203000 - 0xf4203fff (0x1000) MX[B]
[8] -1 0 0xf4202000 - 0xf42020ff (0x100) MX[B]
[9] -1 0 0xf4201000 - 0xf4201fff (0x1000) MX[B]
[10] -1 0 0xf4785000 - 0xf47853ff (0x400) MX[B]
[11] -1 0 0xf4784000 - 0xf47843ff (0x400) MX[B]
[12] -1 0 0xf4780000 - 0xf4783fff (0x4000) MX[B]
[13] -1 0 0xf4700000 - 0xf477ffff (0x80000) MX[B](B)
[14] -1 0 0xf4680000 - 0xf46bffff (0x40000) MX[B](B)
[15] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[16] -1 0 0xf4600000 - 0xf467ffff (0x80000) MX[B](B)
[17] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[18] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[19] -1 0 0x000040d0 - 0x000040df (0x10) IX[B]
[20] -1 0 0x00001574 - 0x00001577 (0x4) IX[B]
[21] -1 0 0x00001370 - 0x00001377 (0x8) IX[B]
[22] -1 0 0x000015f4 - 0x000015f7 (0x4) IX[B]
[23] -1 0 0x000013f0 - 0x000013f7 (0x8) IX[B]
[24] -1 0 0x000040a0 - 0x000040af (0x10) IX[B]
[25] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[26] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[27] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[28] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[29] -1 0 0x00004080 - 0x0000409f (0x20) IX[B]
[30] -1 0 0x00004060 - 0x0000407f (0x20) IX[B]
[31] -1 0 0x00004040 - 0x0000405f (0x20) IX[B]
[32] -1 0 0x00004020 - 0x0000403f (0x20) IX[B]
[33] -1 0 0x00004000 - 0x00004007 (0x8) IX[B](B)
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules//fonts/libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 1.4.0.90, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.4.0.90, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) Matched intel from file name intel.ids in autoconfig
(==) Matched intel for the autoconfigured driver
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: "intel"
(II) Loading /usr/lib/xorg/modules/drivers//intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.4.0.90, module version = 2.2.1
Module class: X.Org Video Driver
(II) LoadModule: "synaptics"
(II) Loading /usr/lib/xorg/modules/input//synaptics_drv.so
(II) Module synaptics: vendor="X.Org Foundation"
compiled for 4.3.99.902, module version = 1.0.0
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 2.0
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 1.4.0, module version = 1.2.3
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
compiled for 1.4.0, module version = 1.2.2
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, 965G, G35, 965Q, 946GZ,
965GM, 965GME/GLE, G33, Q35, Q33, Intel Integrated Graphics Device
(II) Primary Device is: PCI 00:02:0
(–) Assigning device section with no busID to primary device
(WW) intel: No matching Device section for instance (BusID PCI:0:2:1) found
(–) Chipset 945GM found
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[17] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[18] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[19] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[20] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[21] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[22] -1 0 0x000040d0 - 0x000040df (0x10) IX[B]
[23] -1 0 0x00001574 - 0x00001577 (0x4) IX[B]
[24] -1 0 0x00001370 - 0x00001377 (0x8) IX[B]
[25] -1 0 0x000015f4 - 0x000015f7 (0x4) IX[B]
[26] -1 0 0x000013f0 - 0x000013f7 (0x8) IX[B]
[27] -1 0 0x000040a0 - 0x000040af (0x10) IX[B]
[28] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[29] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[30] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[31] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[32] -1 0 0x00004080 - 0x0000409f (0x20) IX[B]
[33] -1 0 0x00004060 - 0x0000407f (0x20) IX[B]
[34] -1 0 0x00004040 - 0x0000405f (0x20) IX[B]
[35] -1 0 0x00004020 - 0x0000403f (0x20) IX[B]
[36] -1 0 0x00004000 - 0x00004007 (0x8) IX[B](B)
[37] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[38] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(II) Loading sub module "int10"
(II) LoadModule: "int10"
(II) Loading /usr/lib/xorg/modules//libint10.so
(II) Module int10: vendor="X.Org Foundation"
(II) Loading sub module "vbe"
(II) LoadModule: "vbe"
(II) Loading /usr/lib/xorg/modules//libvbe.so
(II) Module vbe: vendor="X.Org Foundation"
compiled for 1.4.0.90, module version = 1.1.0
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.4.0.90, module version = 0.1.0
(II) intel(0): Creating default Display subsection in Screen section
"Default Screen" for depth/fbbpp 24/32
(==) intel(0): Depth 24, (==) framebuffer bpp 32
(==) intel(0): RGB weight 888
(==) intel(0): Default visual is TrueColor
(II) intel(0): Integrated Graphics Chipset: Intel(R) 945GM
(–) intel(0): Chipset: "945GM"
(–) intel(0): Linear framebuffer at 0xE0000000
(–) intel(0): IO registers at addr 0xF4600000
(II) intel(0): 2 display pipes available.
(==) intel(0): Using EXA for acceleration
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"(II) Module "ddc" already built-in
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"(II) Module "i2c" already built-in
(II) intel(0): Output VGA using monitor section Configured Monitor
(II) intel(0): I2C bus "CRTDDC_A" initialized.
(II) intel(0): Output LVDS has no monitor section
(II) intel(0): I2C bus "LVDSDDC_C" initialized.
(II) intel(0): I2C device "LVDSDDC_C:ddc2" registered at address 0xA0.
(II) intel(0): EDID vendor "BOE", prod id 2201
(II) Reloading /usr/lib/xorg/modules//libint10.so
(II) intel(0): initializing int10
(WW) intel(0): Bad V_BIOS checksum
(II) intel(0): Primary V_BIOS segment is: 0xc000
(II) intel(0): VESA BIOS detected
(II) intel(0): VESA VBE Version 3.0
(II) intel(0): VESA VBE Total Mem: 7872 kB
(II) intel(0): VESA VBE OEM: Intel(r) 82945GM Chipset Family Graphics Chip Accelerated VGA BIOS
(II) intel(0): VESA VBE OEM Software Rev: 1.0
(II) intel(0): VESA VBE OEM Vendor: Intel Corporation
(II) intel(0): VESA VBE OEM Product: Intel(r) 82945GM Chipset Family Graphics Controller
(II) intel(0): VESA VBE OEM Product Rev: Hardware Version 0.0
(II) intel(0): I2C bus "SDVOCTRL_E for SDVOB" initialized.
(II) intel(0): I2C device "SDVOCTRL_E for SDVOB:SDVO Controller B" registered at address 0x70.
(II) intel(0): I2C bus "SDVOB DDC Bus" initialized.
(II) intel(0): Output TMDS-1 has no monitor section
(II) intel(0): SDVO device VID/DID: 02:3C.06, clock range 25.0MHz - 200.0MHz, input 1: Y, input 2: N, output 1: Y, output 2: N
(II) intel(0): I2C bus "SDVOCTRL_E for SDVOC" initialized.
(II) intel(0): I2C device "SDVOCTRL_E for SDVOC:SDVO Controller C" registered at address 0x72.
(II) intel(0): No SDVO device found on SDVOC
(II) intel(0): I2C device "SDVOCTRL_E for SDVOC:SDVO Controller C" removed.
(II) intel(0): I2C bus "SDVOCTRL_E for SDVOC" removed.
(II) intel(0): Output TV has no monitor section
(II) intel(0): Current clock rate multiplier: 1
(II) intel(0): Output VGA disconnected
(II) intel(0): Output LVDS connected
(II) intel(0): Output TMDS-1 disconnected
(II) intel(0): Output TV disconnected
(II) intel(0): Output LVDS using initial mode 1024x768
(II) intel(0): Monitoring connected displays enabled
(II) intel(0): detected 256 kB GTT.
(II) intel(0): detected 7932 kB stolen memory.
(==) intel(0): video overlay key set to 0x101fe
(==) intel(0): Will not try to enable page flipping
(==) intel(0): Triple buffering disabled
(==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
(==) intel(0): DPI set to (96, 96)
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "exa"
(II) LoadModule: "exa"
(II) Loading /usr/lib/xorg/modules//libexa.so
(II) Module exa: vendor="X.Org Foundation"
compiled for 1.4.0.90, module version = 2.2.0
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"(II) Module "ramdac" already built-in
(II) intel(0): Comparing regs from server start up to After PreInit
(WW) intel(0): Register 0x61200 (PP_STATUS) changed from 0xc0000008 to 0xd0000009
(WW) intel(0): PP_STATUS before: on, ready, sequencing idle
(WW) intel(0): PP_STATUS after: on, ready, sequencing on
(WW) intel(0): Register 0x68000 (TV_CTL) changed from 0x10000000 to 0x000c0000
(WW) intel(0): Register 0x68010 (TV_CSC_Y) changed from 0x00000000 to 0x0332012d
(WW) intel(0): Register 0x68014 (TV_CSC_Y2) changed from 0x00000000 to 0x07d30104
(WW) intel(0): Register 0x68018 (TV_CSC_U) changed from 0x00000000 to 0x0733052d
(WW) intel(0): Register 0x6801c (TV_CSC_U2) changed from 0x00000000 to 0x05c70200
(WW) intel(0): Register 0x68020 (TV_CSC_V) changed from 0x00000000 to 0x0340030c
(WW) intel(0): Register 0x68024 (TV_CSC_V2) changed from 0x00000000 to 0x06d00200
(WW) intel(0): Register 0x68028 (TV_CLR_KNOBS) changed from 0x00000000 to 0x00606000
(WW) intel(0): Register 0x6802c (TV_CLR_LEVEL) changed from 0x00000000 to 0x010b00e1
(WW) intel(0): Register 0x68030 (TV_H_CTL_1) changed from 0x00000000 to 0x00400359
(WW) intel(0): Register 0x68034 (TV_H_CTL_2) changed from 0x00000000 to 0x80480022
(WW) intel(0): Register 0x68038 (TV_H_CTL_3) changed from 0x00000000 to 0x007c0344
(WW) intel(0): Register 0x6803c (TV_V_CTL_1) changed from 0x00000000 to 0x00f01415
(WW) intel(0): Register 0x68040 (TV_V_CTL_2) changed from 0x00000000 to 0x00060607
(WW) intel(0): Register 0x68044 (TV_V_CTL_3) changed from 0x00000000 to 0x80120001
(WW) intel(0): Register 0x68048 (TV_V_CTL_4) changed from 0x00000000 to 0x000900f0
(WW) intel(0): Register 0x6804c (TV_V_CTL_5) changed from 0x00000000 to 0x000a00f0
(WW) intel(0): Register 0x68050 (TV_V_CTL_6) changed from 0x00000000 to 0x000900f0
(WW) intel(0): Register 0x68054 (TV_V_CTL_7) changed from 0x00000000 to 0x000a00f0
(WW) intel(0): Register 0x68060 (TV_SC_CTL_1) changed from 0x00000000 to 0xc1710088
(WW) intel(0): Register 0x68064 (TV_SC_CTL_2) changed from 0x00000000 to 0x4e2d1dc8
(WW) intel(0): Register 0x68070 (TV_WIN_POS) changed from 0x00000000 to 0x00360024
(WW) intel(0): Register 0x68074 (TV_WIN_SIZE) changed from 0x00000000 to 0x02640198
(WW) intel(0): Register 0x68080 (TV_FILTER_CTL_1) changed from 0x00000000 to 0x800010bb
(WW) intel(0): Register 0x68084 (TV_FILTER_CTL_2) changed from 0x00000000 to 0x00028283
(WW) intel(0): Register 0x68088 (TV_FILTER_CTL_3) changed from 0x00000000 to 0x00014141
(WW) intel(0): Register 0x68100 (TV_H_LUMA_0) changed from 0x00000000 to 0xb1403000
(WW) intel(0): Register 0x681ec (TV_H_LUMA_59) changed from 0x00000000 to 0x0000b060
(WW) intel(0): Register 0x68200 (TV_H_CHROMA_0) changed from 0x00000000 to 0xb1403000
(WW) intel(0): Register 0x682ec (TV_H_CHROMA_59) changed from 0x00000000 to 0x0000b060
(==) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don’t.
(II) resource ranges after preInit:
[0] 0 0 0xf4680000 - 0xf46bffff (0x40000) MS[B]
[1] 0 0 0xe0000000 - 0xefffffff (0x10000000) MS[B]
[2] 0 0 0xf4600000 - 0xf467ffff (0x80000) MS[B]
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0xf4000000 - 0xf4000fff (0x1000) MX[B]
[8] -1 0 0xf4100000 - 0xf410ffff (0x10000) MX[B]
[9] -1 0 0xf4204000 - 0xf4204fff (0x1000) MX[B]
[10] -1 0 0xf4203000 - 0xf4203fff (0x1000) MX[B]
[11] -1 0 0xf4202000 - 0xf42020ff (0x100) MX[B]
[12] -1 0 0xf4201000 - 0xf4201fff (0x1000) MX[B]
[13] -1 0 0xf4785000 - 0xf47853ff (0x400) MX[B]
[14] -1 0 0xf4784000 - 0xf47843ff (0x400) MX[B]
[15] -1 0 0xf4780000 - 0xf4783fff (0x4000) MX[B]
[16] -1 0 0xf4700000 - 0xf477ffff (0x80000) MX[B](B)
[17] -1 0 0xf4680000 - 0xf46bffff (0x40000) MX[B](B)
[18] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[19] -1 0 0xf4600000 - 0xf467ffff (0x80000) MX[B](B)
[20] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[21] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[22] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[23] 0 0 0x00004000 - 0x00004007 (0x8) IS[B]
[24] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[25] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[26] -1 0 0x000040d0 - 0x000040df (0x10) IX[B]
[27] -1 0 0x00001574 - 0x00001577 (0x4) IX[B]
[28] -1 0 0x00001370 - 0x00001377 (0x8) IX[B]
[29] -1 0 0x000015f4 - 0x000015f7 (0x4) IX[B]
[30] -1 0 0x000013f0 - 0x000013f7 (0x8) IX[B]
[31] -1 0 0x000040a0 - 0x000040af (0x10) IX[B]
[32] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[33] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[34] -1 0 0x000001f0 - 0x000001f0 (0x1) IX[B]
[35] -1 0 0x000001f0 - 0x000001f7 (0x8) IX[B]
[36] -1 0 0x00004080 - 0x0000409f (0x20) IX[B]
[37] -1 0 0x00004060 - 0x0000407f (0x20) IX[B]
[38] -1 0 0x00004040 - 0x0000405f (0x20) IX[B]
[39] -1 0 0x00004020 - 0x0000403f (0x20) IX[B]
[40] -1 0 0x00004000 - 0x00004007 (0x8) IX[B](B)
[41] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[42] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) intel(0): Kernel reported 843264 total, 1 used
(II) intel(0): I830CheckAvailableMemory: 3373052 kB available
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device or address)
drmOpenDevice: Open failed
drmOpenByBusid: Searching for BusID pci:0000:00:02.0
drmOpenDevice: open result is 8, (OK)
drmOpenByBusid: drmOpenMinor returns 8
drmOpenByBusid: drmGetBusid reports pci:0000:00:02.0
(II) [drm] loaded kernel module for "i915" driver.
(II) [drm] DRM interface version 1.3
(II) [drm] DRM open master succeeded.
(II) intel(0): [drm] Using the DRM lock SAREA also for drawables.
(II) intel(0): [drm] framebuffer mapped by ddx driver
(II) intel(0): [drm] added 1 reserved context for kernel
(II) intel(0): X context handle = 0x1
(II) intel(0): [drm] installed DRM signal handler
(==) intel(0): VideoRam: 262144 KB
() intel(0): Framebuffer compression enabled
) intel(0): Tiling enabled
(II) intel(0): Attempting memory allocation with tiled buffers.
(II) intel(0): Success.
(II) intel(0): [drm] Registers = 0xf4600000
(II) intel(0): [drm] ring buffer = 0xe0000000
(II) intel(0): [drm] mapped front buffer at 0xe0800000, handle = 0xe0800000
(II) intel(0): [drm] mapped back buffer at 0xe1800000, handle = 0xe1800000
(II) intel(0): [drm] mapped depth buffer at 0xe1c00000, handle = 0xe1c00000
(II) intel(0): [drm] mapped classic textures at 0xe2000000, handle = 0xe2000000
(II) intel(0): [drm] Initialized kernel agp heap manager, 33554432
(II) intel(0): [dri] visual configs initialized
(II) intel(0): Page Flipping disabled
(==) intel(0): Write-combining range (0xe0000000,0x10000000)
(II) intel(0): vgaHWGetIOBase: hwp->IOBase is 0x03d0, hwp->PIOOffset is 0x0000
(WW) intel(0): EXA greedy migration mode enabled.
(II) EXA(0): Forcing greedy migration option
(II) EXA(0): Offscreen pixmap area of 12582912 bytes
(II) EXA(0): Driver registered support for the following operations:
(II) Solid
(II) Copy
(II) Composite (RENDER acceleration)
(==) intel(0): Backing store disabled
(==) intel(0): Silken mouse enabled
(II) intel(0): Initializing HW Cursor
(II) intel(0): [DRI] installation complete
(II) intel(0): xf86BindGARTMemory: bind key 0 at 0x00800000 (pgoffset 2048)
(II) intel(0): xf86BindGARTMemory: bind key 1 at 0x00c00000 (pgoffset 3072)
(II) intel(0): xf86BindGARTMemory: bind key 2 at 0x01800000 (pgoffset 6144)
(II) intel(0): xf86BindGARTMemory: bind key 3 at 0x01c00000 (pgoffset 7168)
(II) intel(0): xf86BindGARTMemory: bind key 4 at 0x02000000 (pgoffset 8192)
(II) intel(0): Fixed memory allocation layout:
(II) intel(0): 0x00000000-0x0001ffff: ring buffer (128 kB)
(II) intel(0): 0x00020000-0x0061ffff: compressed frame buffer (6144 kB, 0x00000000d7820000 physical
(II) intel(0): 0x00620000-0x00620fff: compressed ll buffer (4 kB, 0x00000000d7e20000 physical
(II) intel(0): 0x00621000-0x0062afff: HW cursors (40 kB, 0x00000000d7e21000 physical
(II) intel(0): 0x0062b000-0x00632fff: logical 3D context (32 kB)
(II) intel(0): 0x00633000-0x00633fff: overlay registers (4 kB, 0x00000000d7e33000 physical
(II) intel(0): 0x007bf000: end of stolen memory
(II) intel(0): 0x00800000-0x00bfffff: front buffer (4096 kB) X tiled
(II) intel(0): 0x00c00000-0x017fffff: exa offscreen (12288 kB)
(II) intel(0): 0x01800000-0x01bfffff: back buffer (4096 kB) X tiled
(II) intel(0): 0x01c00000-0x01ffffff: depth buffer (4096 kB) X tiled
(II) intel(0): 0x02000000-0x03ffffff: classic textures (32768 kB)
(II) intel(0): 0x10000000: end of aperture
(II) intel(0): fbc disabled on plane a
(II) intel(0): fbc enabled on plane a
(II) intel(0): Output configuration:
(II) intel(0): Pipe A is off
(II) intel(0): Display plane A is now disabled and connected to pipe A.
(II) intel(0): Pipe B is on
(II) intel(0): Display plane B is now enabled and connected to pipe B.
(II) intel(0): Output VGA is connected to pipe none
(II) intel(0): Output LVDS is connected to pipe B
(II) intel(0): Output TMDS-1 is connected to pipe none
(II) intel(0): Output TV is connected to pipe none
(II) intel(0): [drm] dma control initialized, using IRQ 16
(II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
(II) intel(0): DPMS enabled
(II) intel(0): Set up overlay video
(II) intel(0): direct rendering: Enabled
(–) RandR disabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
drmOpenDevice: open result is 9, (OK)
drmOpenByBusid: drmOpenMinor returns 9
(WW) AIGLX: 3D driver claims to not support visual 0x23
(WW) AIGLX: 3D driver claims to not support visual 0x24
(WW) AIGLX: 3D driver claims to not support visual 0x25
(WW) AIGLX: 3D driver claims to not support visual 0x26
(WW) AIGLX: 3D driver claims to not support visual 0x27
(WW) AIGLX: 3D driver claims to not support visual 0x28
(WW) AIGLX: 3D driver claims to not support visual 0x29
(WW) AIGLX: 3D driver claims to not support visual 0x2a
(WW) AIGLX: 3D driver claims to not support visual 0x2b
(WW) AIGLX: 3D driver claims to not support visual 0x2c
(WW) AIGLX: 3D driver claims to not support visual 0x2d
(WW) AIGLX: 3D driver claims to not support visual 0x2e
(WW) AIGLX: 3D driver claims to not support visual 0x2f
(WW) AIGLX: 3D driver claims to not support visual 0x30
(WW) AIGLX: 3D driver claims to not support visual 0x31
(WW) AIGLX: 3D driver claims to not support visual 0x32
(II) AIGLX: Loaded and initialized /usr/lib/dri/i915_dri.so
(II) GLX: Initialized DRI GL provider for screen 0
(II) intel(0): Setting screen physical size to 245 x 184
Atom 4, CARD32 4, unsigned long 4
(II) Synaptics touchpad driver version 0.14.6 (1406)
(–) Synaptics Touchpad auto-dev sets device to /dev/input/event8
() Option "Device" "/dev/input/event8"
) Option "HorizEdgeScroll" "0"
(–) Synaptics Touchpad touchpad found
() Option "SendCoreEvents" "true"
) Synaptics Touchpad: always reports core events
(WW) Configured Mouse: No Device specified, looking for one...
(II) Configured Mouse: Setting Device option to "/dev/input/mice"
(–) Configured Mouse: Device: "/dev/input/mice"
(==) Configured Mouse: Protocol: "Auto"
() Option "CorePointer"
) Configured Mouse: always reports core events
() Option "Device" "/dev/input/mice"
(==) Configured Mouse: Emulate3Buttons, Emulate3Timeout: 50
) Configured Mouse: ZAxisMapping: buttons 4 and 5
() Configured Mouse: Buttons: 9
) Configured Mouse: Sensitivity: 1
() Option "CoreKeyboard"
) Generic Keyboard: always reports core events
() Option "Protocol" "standard"
) Generic Keyboard: Protocol: standard
() Option "AutoRepeat" "500 30"
) Option "XkbRules" "xorg"
() Generic Keyboard: XkbRules: "xorg"
) Option "XkbModel" "pc105"
() Generic Keyboard: XkbModel: "pc105"
) Option "XkbLayout" "kr"
() Generic Keyboard: XkbLayout: "kr"
) Option "XkbVariant" "kr104"
() Generic Keyboard: XkbVariant: "kr104"
) Option "CustomKeycodes" "off"
() Generic Keyboard: CustomKeycodes disabled
(II) evaluating device (Generic Keyboard)
(II) XINPUT: Adding extended input device "Generic Keyboard" (type: KEYBOARD)
(II) evaluating device (Configured Mouse)
(II) XINPUT: Adding extended input device "Configured Mouse" (type: MOUSE)
(II) evaluating device (Synaptics Touchpad)
(II) XINPUT: Adding extended input device "Synaptics Touchpad" (type: MOUSE)
(–) Configured Mouse: PnP-detected protocol: "ExplorerPS/2"
(II) Configured Mouse: ps2EnableDataReporting: succeeded
(II) intel(0): Printing DDC gathered Modelines:
(II) intel(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz)
SetClientVersion: 0 9
SetGrabKeysState - disabled
SetGrabKeysState - enabled
[/code:3w276l2x]
전 와콤을 위한 부분을 추가했지만…
별 이상이 없군요.
Screen 0 "Screen0" 0 0
[color=#0000BF:p1i4dlkn] InputDevice "stylus" "SendCoreEvents"
InputDevice "cursor" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"[/color:p1i4dlkn]
EndSection
Section "Module"
Load "glx"
EndSection
Section "ServerFlags"
Option "Xinerama" "0"
EndSection
Driver "kbd"
Option "XkbOptions" "lv3:ralt_switch"
EndSection
Driver "mouse"
EndSection
Section "Monitor"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "LG T910B"
HorizSync 30.0 - 98.0
VertRefresh 50.0 - 160.0
EndSection
Section "Device"
Driver "nvidia"
Option "NoLogo" "True"
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce FX 5900"
EndSection
Section "Screen"
DefaultDepth 24
Option "AddARGBGLXVisuals" "True"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Videocard0"
Monitor "Monitor0"
DefaultDepth 24
Option "TwinView" "0"
Option "metamodes" "1280x1024_85 +0+0"
EndSection
Section "Extensions"
Option "Composite" "Enable"
EndSection
[color=#0000BF:p1i4dlkn]Section "InputDevice"
Driver "wacom"
Identifier "stylus"
Option "Device" "/dev/input/wacom"
Option "Type" "stylus"
Option "ForceDevice" "ISDV4"
EndSection
Driver "wacom"
Identifier "eraser"
Option "Type" "eraser"
EndSection
Driver "wacom"
Identifier "cursor"
Option "Type" "cursor"
EndSection[/color:p1i4dlkn]
답변 감사합니다.
저도 살펴보니 eraser Section을 넣어주지 않았네요.ㅡㅡ;;;;
Xorg는 정상적으로 올라오는데, Pen의 뒷 부분으로 Eraser를 작동시키고
Pen의 옆 클릭으로 우 클릭을 실행시키려면 어떤 설정을 만져야 하는지요?
저 같은 경우는 펜의 촉과 펜의 뒷 부분 모두 Cursor로 작동하고,
펜의 옆 클릭 시에 지우개가 작동합니다.
TC4400 타블렛 Notebook 입니다만…
