Han-gul is NOT available.
Language support -> Language install/remove -> Installed language
There is Only "English" in installed language.(Attached image)
I want to write Han-gul.
What can I do for it?
[quote="f4strada":glnn1i4v]Han-gul is NOT available.
What can I do for it?[/quote:glnn1i4v]
*One other person reported this problem. Let me know how you install Ubuntu in the first place. (pre-English / pre-Korean selected)
First, Thank you for your answer.
I run "update manager" in many times but nothing changed.
So I installed OS again but problem was same.
My ubuntu file was downloaded official site-"www.ubuntu.com" and 11.04 32bit recommended version.
During installing process, I choose "Korean" and "Korean keyboard 101/104"
and I used all the type of LAN (1 time was using by wireless LAN or the other times was wired LAN)
I really want use linux for my development.
Please help me.
[quote="f4strada":2tphgk9i]First, Thank you for your answer.
Please help me.[/quote:2tphgk9i]
Which server is update server for your ubuntu? (Repository)
Choose the "Main Server" but not the Korean Main Server.
감사합니다. 한글은 해결되었습니다.
그런데 그래픽 드라이버 업데이트하니까 다중 모니터가 안잡히고 있습니다. ^^.
다중모니터도 ndivia 설정들어가서 해결했습니다. 감사합니다. ^^
