Ibus 1.3.8 for 10.10 (maverick)
10.10의 1.3.7버전에서 CPU 100%등을 수정한 안정판으로 나왔네요.
개인적으로 태극문양이 안 깨지고 제대로 나와서 좋습니다.
https://launchpad.net/~shawn-p-huang/+archive/ppa
  • 2010-10-22 ibus 1.3.8 stable release
    o Fix CPU 100% usage with signal.SIGCHLD
    o Destroy existing connection before creating a new connection, and only create the fake context once.
    o Move the candidate window just above the cursor when the window and a preedit string overlap.
    o Enable key snooper by default again
    o Always consume the hotkey, even if the hotkey associated engine already activated.
    o Fix race condition in bus_ibus_impl_create_engine()
    o Fix a build error of IBus-1.0.gir with gobject-introspection 0.9.6
    o Implement stress tool for ibus.
    o Fix a build error with GTK3 gdkkeysyms.h
    o Add time info in log message from satorux@chromium.org
    o Fix memory leak in ibus_input_context_process_key_event by Fujiwarat
    o Fix segv in bus_engine_proxy_process_key_event_reply_cb
    o Fix property issue.
    o Updated many translations.
여전히 마우스로 커서 옮기면 먼저 입력한 글자 복사하나요?
넵, 그건 여전한 것 같습니다.
