Kingsoft Office Alpha12 Patch2 가 나왔네요
안드로이드용 제품은 이미 유명하기때문에 리눅스용도 기대가 되네요. 포럼에 들어가보니 개발자가 케노니컬한테 고맙다는거 보면 케노니컬에서도 관심을 가지는것 같습니다.
스팀OS 도 정식 출시되면 그래픽카드 제조사에서도 드라이버를 신경쓰게 될테니 관련 문제도 많이 해결될것 같습니다.
내년부터는 우분투가 좀더 쓸만해 지지 않을까 생각되네요.
Kingsoft Office for Linux Alpha12 Patch2 [2013-10-28]
What’s new:
1.Added: Restore the sense of crashing.
2.Added: Add a language option of Follow system locale.
3.Added: Add Insert Forms function in Kingsoft Spreadsheets.
4.Fixed: Kingsoft Office crashed when inserting the 32bits bitmap file.
5.Fixed: Kingsoft Office do not support Linux symbol link and physical link.
6.Fixed: The Recent Documents function do not work when using unity desktop.
7.Fixed: Vertical artwords cannot render alphabets correctly.
8.Fixed: Table height error when copy table from Kingsoft Spreadsheets to Kingsoft Writer by RTF format.
9.Fixed: Missing some formulae in Kingsoft Writer.
10.Fixed: Missing the Match case option in Find dialog in Kingsoft Writer.
11.Fixed: Kingsoft Spreadsheets crashed when copying shapes from Kingsoft Writer.
12.Fixed: Cannot insert Cross-reference footnote in Chinese version of Kingsoft Writer.
13.Fixed: The Simplified and Traditional Chinese conversion function cannot work after copying the data by RTF format in Kingsoft Writer.
14.Fixed: Cannot play sound in special PPTX files.
15.Fixed: Kingsoft Spreadsheets crashed when system printer driver is not completed.
16.Fixed: Lacking of text in a textbox when saving as ET/XLS formats in Kingsoft Spreadsheets.
17.Fixed: Cannot correct drawing combined shapes in Kingsoft Spreadsheets.
18.Fixed: Cannot read XLSX in some regions which using comma as decimal point.
19.Fixed: The Iteration calculation function cannot work in Kingsoft Spreadsheets.
20.Fixed: Cannot modify styles in Chinese verison of Kingsoft Spreadsheets.
21.Fixed: Cross-workbook references update error in Kingsoft Spreadsheets.
22.Fixed: Lacking of hyperlinks when saving as XLS format in Kingsoft Spreadsheets.
사용해 보지는 않았지만 좋은 무른모가 많이 생겼으면 합니다
특히 M$ 오피스와 호환성을 좀 신경써 줬으면 합니다
libre의 경우 2010으로 만든 파일의 경우
일부 깨지는 파일이 많던데 빨리 해결되었으면 좋겠습니다
그리고 한컴에서는 뷰어라도 내놓거나 아니면 소스라도 제대로
공개해줬으면 좋겠습니다. 제발 부탁이니까…
아니면 한글2008말고 새로운 버전을 만들어 주던가
하여튼 문제가 많네요…
p.s. 그리고 요새 윈도우8.1용 태블릿은 많이 나오는데
리눅스 설치되는 거 없나요?
베이트레일용 커널이 제대로 없는 걸로 아는데 인텔에서 왜
지원을 안해주는지 모르겠습니다.
