[quote="benjen":1wpzgy97]콘키 멋있네요.
콘키 설정한 내용 공유해주실 수 있나요.
sudo gedit ~/.conkyrc[/quote:1wpzgy97]
Kubuntu에선 kate죠
아래 내용을 올바로 표현하기 위해선
[url=http://gnome-look.org/content/show.php/CONKY-colors?content=92328:1wpzgy97]CONKY-colors GNOME-Look.org[/url:1wpzgy97]에 포함된 폰트를 설치해야 합니다. (폰트만…)
그리고
[url=http://ubuntuforums.org/showthread.php?t=869328:1wpzgy97]Conky Weather Forecast Python Script[/url:1wpzgy97]
[url=http://ubuntuforums.org/showthread.php?t=869771:1wpzgy97]Conky SSL Email Python Script[/url:1wpzgy97]를 설치해야 합니다.
시계는 적당한 고정폭 글꼴로 지정해주시면 됩니다. (안그럼 1시 또는 1분이 표시될 때 시계가 이쪽 저쪽으로 움직입니다.)
[code:1wpzgy97]# Use Xft?
use_xft yes
xftfont DejaVu Sans:size=8
xftalpha 0.8
text_buffer_size 2048
Update interval in seconds
update_interval 1
This is the number of times Conky will update before quitting.
Set to zero to run forever.
total_run_times 0
Create own window instead of using desktop (required in nautilus)
own_window yes
own_window_transparent yes
own_window_type override
own_window_hints undecorated,below,sticky,skip_taskbar,skip_pager
Use double buffering (reduces flicker, may not work for everyone)
double_buffer yes
Minimum size of text area
minimum_size 180 0
#maximum_width 210
Draw shades?
draw_shades no
Draw outlines?
draw_outline no
Draw borders around text
draw_borders no
Stippled borders?
stippled_borders 0
border margins
border_margin 5
border width
border_width 1
Default colors and also border colors
default_color white
#default_shade_color black
#default_outline_color white
own_window_colour white
Text alignment, other possible values are commented
#alignment top_left
alignment top_right
#alignment bottom_left
#alignment bottom_right
Gap between borders of screen and text
same thing as passing -x at command line
gap_x 25
gap_y 60
Subtract file system buffers from used memory?
no_buffers yes
set to yes if you want all text to be in uppercase
uppercase no
number of cpu samples to average
set to 1 to disable averaging
cpu_avg_samples 2
number of net samples to average
net_avg_samples 2
Force UTF8? note that UTF8 support required XFT
override_utf8_locale yes
Add spaces to keep things from moving about? This only affects certain objects.
use_spacer none
TEXT
SYSTEM ${hr 2}
${voffset 4}${font OpenLogos:size=16}u${font} ${voffset -5}Kernel: ${alignr}${kernel}
${voffset 4}${font StyleBats:size=16}A${font} ${voffset -5}CPU1: ${cpu cpu1}% ${alignr}${cpubar cpu1 8,60}
${voffset 4}${font StyleBats:size=16}A${font} ${voffset -5}CPU2: ${cpu cpu2}% ${alignr}${cpubar cpu2 8,60}
${voffset 4}${font StyleBats:size=16}g${font} ${voffset -5}RAM: $memperc% ${alignr}${membar 8,60}
${voffset 4}${font StyleBats:size=16}j${font} ${voffset -5}SWAP: $swapperc% ${alignr}${swapbar 8,60}
${voffset 4}${font StyleBats:size=16}q${font} ${voffset -5}Uptime: ${alignr}${uptime}
DATE ${hr 2}
${alignc 57}${font Army:size=42}${time %H:%M}${font}
${font LexiGulim:style=Bold:pixelsize=14}${alignc}${time %Y년} ${time %B %e일 (%a)}${font}$color
HD ${hr 2}
${voffset 4}${font Pie charts for maps:size=14}7${font} ${voffset -5}Root:
${voffset 4}${fs_used /}/${fs_size /} ${alignr}${fs_bar 8,60 /}
${font Pie charts for maps:size=14}7${font} ${voffset -5}Home:
${voffset 4}${fs_used /home}/${fs_size /home} ${alignr}${fs_bar 8,60 /home}
${font Pie charts for maps:size=14}7${font} ${voffset -5}Data:
${voffset 4}${fs_used /media/Data}/${fs_size /media/Data} ${alignr}${fs_bar 8,60 /media/Data}
${font Pie charts for maps:size=14}7${font} ${voffset -5}Media:
${voffset 4}${fs_used /media/disk}/${fs_size /media/disk} ${alignr}${fs_bar 8,60 /media/disk}
NETWORK ${hr 2}
${voffset 4}${font PizzaDude Bullets:size=14}O${font} Up: ${upspeed eth0} kb/s ${alignr}${upspeedgraph eth0 8,60 3465A4 729FCF}
${voffset 4}${font PizzaDude Bullets:size=14}U${font} Dn: ${downspeed eth0} kb/s ${alignr}${downspeedgraph eth0 8,60 3465A4 729FCF}
${voffset 4}${font PizzaDude Bullets:size=14}N${font} Upload: ${alignr}${totalup eth0}
${voffset 4}${font PizzaDude Bullets:size=14}T${font} Download: ${alignr}${totaldown eth0}
${voffset 4}${font PizzaDude Bullets:size=14}a${font} Local Ip: ${alignr}${addr eth0}
EMail ${hr 2}
${execpi 60 conkyEmail --template=/usr/share/conkyemail/example/conkyEmail.template}
WEATHER ${hr 2}
${if_existing /proc/net/route wlan0}
${voffset -10}${alignr 56}${font ConkyWeather:style=Bold:size=40}${execi 600 conkyForecast --location=KSXX0050 --datatype=WF}${font}
${voffset -50}${font Weather:size=40}y${font} ${voffset -38}${font Arial Black:size=26}${execi 600 conkyForecast --location=KSXX0050 --datatype=HT}${font}
${voffset 0}${alignc 43}${execpi 600 conkyForecast --location=KSXX0050 --datatype=DW --startday=1 --shortweekday} ${alignc 8}${execpi 600 conkyForecast --location=KSXX0050 --datatype=DW --startday=2 --shortweekday} ${alignc -29}${execpi 600 conkyForecast --location=KSXX0050 --datatype=DW --startday=3 --shortweekday} ${alignc -64}${execpi 600 conkyForecast --location=KSXX0050 --datatype=DW --startday=4 --shortweekday}
${voffset 0}${alignc 75}${font ConkyWeather:size=28}${execpi 600 conkyForecast --location=KSXX0050 --datatype=WF --startday=1 --endday=4 --spaces=1}${font}
${voffset 0}${font DejaVu Sans:size=7}${alignc 48}${execpi 600 conkyForecast --location=KSXX0050 --datatype=HT --startday=1 --hideunits --centeredwidth=3}/${execpi 600 conkyForecast --location=KSXX0050 --datatype=LT --startday=1 --hideunits --centeredwidth=3} ${alignc -14}${execpi 600 conkyForecast --location=KSXX0050 --datatype=HT --startday=2 --hideunits --centeredwidth=3}/${execpi 600 conkyForecast --location=KSXX0050 --datatype=LT --startday=2 --hideunits --centeredwidth=3} ${alignc -40}${execpi 600 conkyForecast --location=KSXX0050 --datatype=HT --startday=3 --hideunits --centeredwidth=3}/${execpi 600 conkyForecast --location=KSXX0050 --datatype=LT --startday=3 --hideunits --centeredwidth=3} ${alignr 6}${execpi 600 conkyForecast --location=KSXX0050 --datatype=HT --startday=4 --hideunits --centeredwidth=3}/${execpi 600 conkyForecast --location=KSXX0050 --datatype=LT --startday=4 --hideunits --centeredwidth=3}${font}
${else}${if_existing /proc/net/route eth0}
${endif}${else}${if_existing /proc/net/route eth1}
${endif}${else}
${font PizzaDude Bullets:size=14}4${font} Weather Unavailable
${endif}[/code:1wpzgy97]
날씨 부분은 저렇게 다쓸 필요 없는데, 귀찮아서 그냥 두고 씁니다.
