이번에 USB 타입 기가비트 랜카드를 하나 구매해서 Ubuntu 10.04에서 사용중인데
인식 잘되고 동작 잘되네요…
속도는 조금 미흡하지만 아마도 케이블 문제 같습니다.
혹시 다른 제품을 사용하고 계신분 있으시면 알려주세요
제조사 : COMS
제품 : ASIX AX88178 USB 2.0 Ethernet
lshw -C network | tail -7
WARNING: you should run this program as super-user.
*-network:1
description: Ethernet interface
physical id: 2
logical name: eth2
serial: 00:80:c9:00:09:46
capabilities: ethernet physical
configuration: broadcast=yes driver=asix driverversion=14-Jun-2006 firmware=ASIX AX88178 USB 2.0 Ethernet ip=192.168.0.69 multicast=yes
$ sudo ethtool eth2
[sudo] password for ihavnoth:
Settings for eth2:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Advertised pause frame use: No
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
1000baseT/Full
Link partner advertised pause frame use: No
Link partner advertised auto-negotiation: Yes
Speed: 1000Mb/s
Duplex: Full
Port: MII
PHYAD: 1
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: pg
Wake-on: d
Current message level: 0x00000007 (7)
Link detected: yes
