무선랜(usb) rt2870 드라이버 설치관련
라링크 홈페이지에서 리눅스 버전 RT2870 드라이버를 다운 받았는데요.
빨간색으로 해놓은 부분부터 막힙니다…ㅠ_ㅠ
해결방법이 없을까요? 운영체제는 win7과 코분투 10.10을 사용하고 있습니다.
데스크탑입니다…ㅜㅜ
1> $tar -xvzf DPB_RT2870_Linux_STA_x.x.x.x.tgz
go to "./DPB_RT2870_Linux_STA_x.x.x.x" directory.
2> In Makefile
set the "MODE = STA" in Makefile and chose the TARGET to Linux by set "TARGET = LINUX"
define the linux kernel source include file path LINUX_SRC
modify to meet your need.
3> In os/linux/config.mk
define the GCC and LD of the target machine
define the compiler flags CFLAGS
** Build for being controlled by NetworkManager or wpa_supplicant wext functions
  Please set 'HAS_WPA_SUPPLICANT=y' and 'HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=y'.
[color=#FF0000:h4lakti7] => #>cd wpa_supplicant-x.x[/color:h4lakti7]
=> #>./wpa_supplicant -Dwext -ira0 -c wpa_supplicant.conf -d
** Build for being controlled by WpaSupplicant with Ralink Driver
  Please set 'HAS_WPA_SUPPLICANT=y' and 'HAS_NATIVE_WPA_SUPPLICANT_SUPPORT=n'.
  => #>cd wpa_supplicant-0.5.7
  => #>./wpa_supplicant -Dralink -ira0 -c wpa_supplicant.conf -d
4> $make
# compile driver source code
# To fix "error: too few arguments to function ‥iwe_stream_add_event"
 => $patch -i os/linux/sta_ioctl.c.patch os/linux/sta_ioctl.c
5> $cp RT2870STA.dat /etc/Wireless/RT2870STA/RT2870STA.dat
6> load driver, go to "os/linux/" directory.
#[kernel 2.4]
#    $/sbin/insmod rt2870sta.o
#    $/sbin/ifconfig ra0 inet YOUR_IP up
#[kernel 2.6]
#    $/sbin/insmod rt2870sta.ko
7> unload driver
$/sbin/ifconfig ra0 down
$/sbin/rmmod rt2870sta
빨강색 글자 이름하고 비슷한 디렉토리로 가서 그 밑에 명령을 수행하면 될듯해요. x.x 되있는건 버전숫자를 적시하지 않은거 같아보입니다.
그런 폴더가 전혀보이질 않아서요…ㅠㅠ
