.xsession-errors파일 질문입니다
개정 홈 디렉토리를 보면 .xsession-errors파일이 있는데 이게 x가 올라오면서
오류를 남기는것 같습니다.
오류의 내용을 보았는데 뭐가 문제인지 모르겟습니다.
주로 evolution의 태그쪽 문제인듯 싶은데…어떻게 해결해야 할지 잘 몰라 글을 올립니다.
파일의 내용은 다음과 같습니다.
/etc/gdm/Xsession: Beginning session setup…
Setting IM through im-switch for locale=ko_KR.
Start IM through /home/sanggoni/.xinput.d/ko_KR linked to /etc/X11/xinit/xinput.d/scim-hangul.
Unable to create /home/sanggoni/.dbus/session-bus
Smart Common Input Method 1.4.7
Launching a SCIM daemon with Socket FrontEnd…
Loading simple Config module …
Creating backend …
Loading socket FrontEnd module …
Starting SCIM as daemon …
Launching a SCIM process with x11…
Loading socket Config module …
Creating backend …
Loading x11 FrontEnd module …
GTK Panel of SCIM 1.4.7
SCIM has been successfully launched.
x-session-manager[6125]: WARNING: Unable to find provider ‘gnome-wm’ of required component ‘windowmanager’
Checking for Xgl: not present.
Detected PCI ID for VGA:
Checking for texture_from_pixmap: not present.
Trying again with indirect rendering:
Checking for texture_from_pixmap: present.
Checking for non power of two support: present.
Checking for Composite extension: present.
Comparing resolution (1680x1050) to maximum 3D texture size (8192): Passed.
Checking for Software Rasterizer: Not present.
Checking for nVidia: not present.
Checking for FBConfig: present.
/usr/bin/compiz.real (video) - Warn: No 8 bit GLX pixmap format, disabling YV12 image format
x-session-manager[6125]: WARNING: Application ‘gnome-wm.desktop’ failed to register before timeout
seahorse nautilus module initialized
Initializing nautilus-open-terminal extension
Initializing nautilus-share extension
** (nautilus:6340): WARNING **: Unable to add monitor: 지원되지 않음
(gnome-panel:6338): Gtk-WARNING **: gtk_widget_size_allocate(): attempt to allocate widget with width -153 and height 27
E: thread-posix.c: Assertion ‘pthread_setspecific(t->key, userdata) == 0’ failed at pulsecore/thread-posix.c:194, function pa_tls_set(). Aborting.
x-session-manager[6125]: WARNING: Application ‘libcanberra-login-sound.desktop’ failed to register before timeout
Failure: Module initalization failed
** (nm-applet:6389): WARNING **: No connections defined
ERROR: trackerd already running on your session dbus - exiting…
evolution-alarm-notify-Message: Setting timeout for 58265 1225810800 1225752535
evolution-alarm-notify-Message: Wed Nov 5 00:00:00 2008
evolution-alarm-notify-Message: Tue Nov 4 07:48:55 2008
e-data-server-ui-Message: Unable to find password(s) in keyring (Keyring reports: 해당하는 사항 없음)
e-data-server-ui-Message: 키 파일에 ‘Passwords-한국기념일, 음력’ 그룹이 없습니다
창 관리자 주의: 저장된 세션 파일 /home/sanggoni/.config/metacity/sessions/105dc29668c2d5cf7e122575250863003800000061250001.ms을(를) 읽기 실패: 파일 ‘/home/sanggoni/.config/metacity/sessions/105dc29668c2d5cf7e122575250863003800000061250001.ms’ 열기 실패 : No such file or directory
(nautilus:6340): Gdk-WARNING **: /build/buildd/gtk+2.0-2.14.4/gdk/x11/gdkproperty-x11.c:318 invalid X atom: -1
PID TTY TIME CMD
6219 ? 00:00:00 pulseaudio
6338
Bad UTF-8 in startup notification message
** (evolution:6702): DEBUG: mailto URL command: evolution %s
** (evolution:6702): DEBUG: mailto URL program: evolution
Can’t open file ‘wordlist.db’ in directory ‘/home/sanggoni/.bogofilter’.
error #2 - No such file or directory.
Remember to register some spam and ham messages before you
use bogofilter to evaluate mail for its probable spam status!
(evolution:6702): Gtk-CRITICAL **: gtk_widget_get_screen: assertion `GTK_IS_WIDGET (widget)’ failed
(evolution:6702): Gdk-CRITICAL **: gdk_screen_is_composited: assertion `GDK_IS_SCREEN (screen)’ failed
(evolution:6702): Gdk-CRITICAL **: gdk_screen_is_composited: assertion GDK_IS_SCREEN (screen)' failed (evolution:6702): Gtk-CRITICAL **: gtk_widget_get_screen: assertion GTK_IS_WIDGET (widget)’ failed
Saving 11/11 dirty records of Inbox
Saving 1/11 dirty records of Inbox
Saving 1/1 dirty records of 0.개인편지보관함/1.영어편지보관함
Changing the queries (contains? "summary" "")
e-data-server-ui-Message: 키 파일에 ‘Passwords-Calendar’ 그룹이 없습니다
(evolution:6702): Gdk-CRITICAL **: gdk_screen_is_composited: assertion GDK_IS_SCREEN (screen)' failed (evolution:6702): e-data-server-ui-CRITICAL **: ep_keyring_insert_password: assertion user != NULL’ failed
(evolution:6702): Gtk-CRITICAL **: gtk_widget_get_screen: assertion GTK_IS_WIDGET (widget)' failed (evolution:6702): Gdk-CRITICAL **: gdk_screen_is_composited: assertion GDK_IS_SCREEN (screen)’ failed
(nautilus:6340): Gdk-WARNING **: /build/buildd/gtk+2.0-2.14.4/gdk/x11/gdkproperty-x11.c:318 invalid X atom: 36122192
창 관리자 주의: Buggy client sent a _NET_ACTIVE_WINDOW message with a timestamp of 0 for 0x48000ce (Mozilla Fi)
창 관리자 주의: meta_window_activate called by a pager with a 0 timestamp; the pager needs to be fixed.
(npviewer.bin:7428): Gtk-CRITICAL **: gtk_style_detach: assertion style->attach_count > 0' failed (npviewer.bin:7428): Gtk-CRITICAL **: gtk_widget_destroy: assertion GTK_IS_WIDGET (widget)’ failed
(npviewer.bin:7428): Gtk-CRITICAL **: gtk_style_detach: assertion `style->attach_count > 0’ failed
(npviewer.bin:7428): Gtk-CRITICAL **: gtk_widget_destroy: assertion `GTK_IS_WIDGET (widget)’ failed
(npviewer.bin:7480): Gtk-CRITICAL **: gtk_style_detach: assertion `style->attach_count > 0’ failed
(gnome-sound-properties:7748): sound-properties-DEBUG: setting theme ubuntu
사용하는데 큰 지장이 없으시면 그냥 로그 파일이므로…신경쓰지 마세요.
프로그램 일일이 버그 잡아 수정하고 개발팀에게 보고하고 하실수 있으시면 개선이 되고 해결이 되겠지요.
에볼류션 전에 설정하신것이 문제 인거 같은데…
에볼류선 설정 백업 후 재설정 이 필요 하거나…
음력달력 또는 그릅을 다시 만들어 보십시요
새버전에서 전 설정 적용이 잘 안되나 음…
