우분투 9.04 서버설치후 bind9와 네트워크 및 호스트 설정 문의
사용환경
우분투 9.04 서버
amd 3200+
ram 1gram
기본정보입니다.
도메인 interbank.or.kr
네임서버 ns1.interbank.or.kr
ip = X.151.74.227
bind9 설정 상태========================================================
zone "ns1.interbank.or.kr" IN{
type master;
file "/etc/bind/db-interbank";
zone "interbank.or.kr" IN{
type master;
zone "74.151.X.in-addr.arpa" IN{
type master;
file "/etc/bind/ip-interbank";
zone "0.0.127.in-addr.arpa" IN{
type master;
file "/etc/bind/loopback-interbank";
root@interbank:/etc/bind# cat db-interbank
; BIND data file for local loopback interface
$TTL 604800
@ IN SOA ns1.interbank.or.kr. root.interbank.or.kr. (
                           2008051612    ; Serial
                           604800        ; Refresh
                           86400         ; Retry
                           2419200       ; Expire
                           604800 )      ; Negative Cache TTL
@ IN NS ns1.interbank.or.kr.
A x.151.74.227
www A x.151.74.227
file A x.151.74.227
root@interbank:/etc/bind# cat ip-interbank
;; BIND data file for local loopback interface
$TTL 604800
2008051612 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
5 PTR interbank.or.kr
5 PTR http://www.interbank.or.kr
5 PTR file.interbank.or.kr
root@interbank:/etc/bind# cat loopback-interbank
;; BIND reverse data file for local loopback interface
$TTL 604800
2008051612 ; Serial
604800 ; Refresh
86400 ; Retry
2419200 ; Expire
1 PTR localhost.
root@interbank:/etc/bind# cat /etc/network/interfaces
This file describes the network interfaces available on your system
and how to activate them. For more information, see interfaces(5).
The loopback network interface
auto lo
iface lo inet loopback
The primary network interface
auto eth0
iface eth0 inet static
address x.151.74.227
netmask 255.255.255.x
gateway x.151.74.225
dns-nameservers 203.248.252.2 164.124.101.2
    # dns-* options are implemented by the resolvconf package, if installed
root@interbank:/etc/bind# cat /etc/resolv.conf
search interbank.or.kr
nameserver 203.248.252.2
nameserver x.151.74.227
root@interbank:/etc/bind# hostname
interbank.or.kr
일단 기본설정은 이러합니다 고정아이피는 보유중인거구요
현제 ns1.interbank.or.kr 로는 nsloockup 해서 정보나오고 핑도 나가는데요
interbank.or.kr 로는 연결이 안되고 있습니다.
10시간 삽질해서 이정도 했는데 뭐가 잘못된걸까요 고수님들의 조언을 부탁드립니다
빠진게 있으면 말씀해주십시요
기본적으로 도메인 과 네임서버 네트웍설정을 할줄모르는 상태에서 했기때문에
ns1.interbank.or.kr 즉 ns1 을 호스트 등록 하십시요 오XX XX(주) 에서
그리고
ns1.interbank.or.kr 와 interbank.or.kr 의 존파일을 따로 하십시요
[quote="noorygo":fe8f4voe]@ IN NS ns1.interbank.or.kr.
5 PTR file.interbank.or.kr[/quote:fe8f4voe] 이부분 왜 이리 하신지 이해 안감니다
다른 IP 서버로 보낼꺼면 interbank.or.kr 의 존파일에서 아이피 전부 적어 주십시요!
5 PTR http://www.interbank.or.kr 이런 문법 자체가 없습니다.
어떤 문서 참고 하셨는지요
우분투적인 문서라면 머가 좋으려나
우선 아래 두링크 참고바랍니다.
https://help.ubuntu.com/community/BIND9ServerHowto http://www.ubuntugeek.com/dns-server-se ... buntu.html
noorygo 님의 글:
[color=#BFFF00:26gjzplt]5 PTR http://www.interbank.or.kr[/color:26gjzplt]
저부분은 여기에 글올리니까 http://www 이게 붙은거에용
일단 참고는 ubntu.or.kr 시작 페이지의 bind9 설정 따라했습니다.
아직 존파일 과 named.conf 에 내용도 이해를 못하는 실정이긴합니다.
도메인 등록업체에 ns1 호스트등록하고 ip현제 가지고있는거 등록했어요 현제 ip는 58.151.74.227 ip로는 접속이 되고있고요
존파일을 호스트인 ns1과 도메인인 interbank.or.kr 을 따로 생성하라는 말씀이 이해가 잘안가구요
어제까지는 bind9 restart 해도 ok 잘됬는데 지금은 또 127.0.0.1 conneting 오류로 나오네요 ㅠㅠ
정말 바쁘시고 번거롭겠지만 좀 알려주실수 있을까요 일단 참고할수있는 한글문서 있으면 우선 정독부터 하겠습니다 링크좀 알려주세요ㅠㅠ
[quote="noorygo":xjpo0ep2]일단 참고는 ubntu.or.kr 시작 페이지의 bind9 설정 따라했습니다.[/quote:xjpo0ep2] 제가 적은건 아니고
IRC 에서 아는 어떤 이인데 누구더라?
잘 된 글은 아니고 제가 조금 가르쳐 주었는데 감사 표시로 적은 글입니다. 초기에 하도 글없어 가르쳐주면 적으라고 했던…
[quote="noorygo":xjpo0ep2]존파일을 호스트인 ns1과 도메인인 interbank.or.kr 을 따로 생성하라는 말씀이 이해가 잘안가구요[/quote:xjpo0ep2]이유는 두가지 입니다.
  1. interbank.or.kr의 여러 호스트 생성 분리 운영
  2. 타도메인의 네임서버 등록 (ns1.interbank.or.kr) 후 운영
[quote="noorygo":xjpo0ep2]어제까지는 bind9 restart 해도 ok 잘됬는데 지금은 또 127.0.0.1 conneting 오류로 나오네요 ㅠㅠ[/quote:xjpo0ep2]
bind9 재시작에 관한 메세지는 재시작후 /var/log/daemon.log 파일 끝 살펴 보십시요!
[quote="noorygo":xjpo0ep2]한글문서 있으면 우선 정독부터 하겠습니다 링크좀 알려주세요ㅠㅠ[/quote:xjpo0ep2] 그간 여러명 가르쳐준 경험으로 보면 네임서버가 문서 읽어도 감이 잘 안옵니다.
한글 문서로는 파워DNS 하고 김정균님 글이 갠찮습니다.
http://wiki.kldp.org/KoreanDoc/html/PoweredByDNS-KLDP/ http://oops.org/?t=lecture&s=bind9
Jun 5 17:14:50 #interbank
interbank named[562]: starting BIND 9.5.1-P2 -u bind
interbank named[562]: found 1 CPU, using 1 worker thread
interbank named[562]: using up to 4096 sockets
interbank named[562]: loading configuration from ‘/etc/bind/named.conf’
interbank named[562]: none:0: open: /etc/bind/named.conf: permission denied
interbank named[562]: loading configuration: permission denied
interbank named[562]: exiting (due to fatal error)
퍼미션문제인거같은데;;
고맙고 죄송하고 미치겠어요 ㅠㅠ
고맙습니다. 강분도님 정말 많은 도움이 되었습니다.
링크해주신 두곳 과 http://dns.nida.kr/main.jsp 이곳을 통해서
해결을 했습니다.
[quote="noorygo":db05e10o]고맙습니다. 강분도님 정말 많은 도움이 되었습니다.
해결을 했습니다.[/quote:db05e10o] 에고 잘 해결하셨다니 기쁩니다.
nida에서도 좋은 문서가 있군요 다음에 비슷한 질문자 있을시 권하겠습니다.
네임서버가 좀 간단치 않터 라고요
배포판마다 조금씩 위치도 다르고…
이제 그 설정과 활용에 [b:db05e10o]시작을 하게 된걸 축하[/b:db05e10o] 드리니다. ;)
