Datasheet for LG's LGDT3304 and 3305
I’m writing in English and I hope the best person for this sees it. I’m trying to help the Linux4TV developers at Kernel Labs [url:mhsbk23i]http://www.kernellabs.com/blog/[/url:mhsbk23i] find some datasheets from LG Electronics. I’ve drawn a blank on the internet. The datasheets aren’t there. I’ve tried contacting LG in America. That’s not working either. Steve Toth and Devin Heitmueller at KernelLabs can both sign non-disclosure agreements, if necessary.
The KernelLabs team is in need of datasheets, including info about "register description and programing specifications".
the part numbers are:
LGDT3304
and
LGDT3305
if you would be so kind as to contact someone at LG-Korea and ask them for this information in English. I can be emailed at: emarkpreston-at-hotmail-dot-com, and please send the .pdf-s there to me at that address if at all possible.
P.S. - I am trying to help the guys write drivers for my AVermedia pci-e dual tuner ATSC video card. My rig is an AMD II X4 620 (Propus) with 2 gig ram, an EVGA 9500GT (1gig) vid card, 400gig seagate SATA 3gig drive. I run Lucid lynx 10.04 currently.
Thanks a bunch.
Mark_in_Hollywood
허접한 번역실력으로 번역을 해보자면…
현재 Linux4TV 개발에 LGDT3304와 LGDT3305 이 두 칩셋의 datasheet가 필요하다고 합니다.
(레지스터 설명서 및 프로그램 스펙이 포함된)
입수에 성공하면 datasheet를 pdf 형식으로 emarkpreston@hotmail.com 으로 보내달라…라고 하시는군요.
(입수만 하는 정도가 아니라 누구나 열람 가능하게 되어야 될 겁니다. 아마도)
미국 쪽 LG에는 연락을 취해 보았지만 소용없었다고 합니다.
혹시 한국 쪽 LG에 연락해 보실 분?
