취미삼아 웹서버로 운용하는 우분투가 하나 있습니다.
여느날과 같이 업데이트를 하는데 용량이 가득 찼다며 업데이트를 할 수 없었습니다.
$ sudo apt-get update
Ign:1 http://us.archive.ubuntu.com/ubuntu focal InRelease
Get:2 https://artifacts.elastic.co/packages/7.x/apt stable InRelease [13.7 kB]
Ign:3 http://ppa.launchpad.net/ondrej/php/ubuntu focal InRelease
Err:2 https://artifacts.elastic.co/packages/7.x/apt stable InRelease
Couldn't create temporary file /tmp/apt.conf.NcZqRk for passing config to apt-key
Ign:4 http://security.ubuntu.com/ubuntu focal-security InRelease
Get:5 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease [114 kB]
Err:6 http://ppa.launchpad.net/ondrej/php/ubuntu focal Release
Could not open file /var/lib/apt/lists/partial/ppa.launchpad.net_ondrej_php_ubuntu_dists_focal_Release - open (28: No space left on device) [IP: 91.189.95.85 80]
Err:7 http://security.ubuntu.com/ubuntu focal-security Release
Could not open file /var/lib/apt/lists/partial/security.ubuntu.com_ubuntu_dists_focal-security_Release - open (28: No space left on device) [IP: 91.189.91.38 80]
Err:5 http://us.archive.ubuntu.com/ubuntu focal-updates InRelease
Couldn't create temporary file /tmp/apt.conf.F39QHn for passing config to apt-key
Err:8 http://us.archive.ubuntu.com/ubuntu focal Release
Could not open file /var/lib/apt/lists/partial/us.archive.ubuntu.com_ubuntu_dists_focal_Release - open (28: No space left on device) [IP: 91.189.91.38 80]
** (appstreamcli:892436): CRITICAL **: 14:03:58.756: Unable to open temporary cache: Unable to open temporary cache file: No space left on device
File "/usr/lib/cnf-update-db", line 26, in <module>
col.create(db)
File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 108, in create
os.rename(tmpdb, dbname)
OSError: [Errno 28] No space left on device: '/var/lib/command-not-found/commands.db.tmp' -> '/var/lib/command-not-found/commands.db'
Error in sys.excepthook:
File "/usr/lib/python3/dist-packages/apport_python_hook.py", line 153, in apport_excepthook
with os.fdopen(os.open(pr_filename,
OSError: [Errno 28] No space left on device: '/var/crash/_usr_lib_cnf-update-db.0.crash'
Original exception was:
col.create(db)
Reading package lists... Error!
W: GPG error: https://artifacts.elastic.co/packages/7.x/apt stable InRelease: Couldn't create temporary file /tmp/apt.conf.NcZqRk for passing config to apt-key
E: The repository 'https://artifacts.elastic.co/packages/7.x/apt stable InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
E: The repository 'http://ppa.launchpad.net/ondrej/php/ubuntu focal Release' no longer has a Release file.
E: The repository 'http://security.ubuntu.com/ubuntu focal-security Release' does not have a Release file.
W: GPG error: http://us.archive.ubuntu.com/ubuntu focal-updates InRelease: Couldn't create temporary file /tmp/apt.conf.F39QHn for passing config to apt-key
E: The repository 'http://us.archive.ubuntu.com/ubuntu focal-updates InRelease' is not signed.
E: The repository 'http://us.archive.ubuntu.com/ubuntu focal Release' does not have a Release file.
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
E: Unable to mkstemp /tmp/clearsigned.message.1SYkdy - GetTempFile (2: No such file or directory)
E: The package lists or status file could not be parsed or opened.
로그가 가득 쌓여서 그런가 싶어 로그를 지웠는데 그래도 용량이 모자르다고 합니다.
저장공간은 충분한거 같습니다.
$ df -h
Filesystem Size Used Avail Use% Mounted on
udev 1.9G 0 1.9G 0% /dev
tmpfs 381M 40M 342M 11% /run
/dev/sda2 41G 15G 26G 37% /
tmpfs 1.9G 0 1.9G 0% /dev/shm
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 1.9G 0 1.9G 0% /sys/fs/cgroup
/dev/loop7 56M 56M 0 100% /snap/core18/2066
/dev/loop5 219M 219M 0 100% /snap/gnome-3-34-1804/66
/dev/loop2 100M 100M 0 100% /snap/core/10908
/dev/loop1 162M 162M 0 100% /snap/gnome-3-28-1804/128
/dev/loop9 2.3M 2.3M 0 100% /snap/gnome-system-monitor/148
/dev/loop10 218M 218M 0 100% /snap/gnome-3-34-1804/60
/dev/loop4 100M 100M 0 100% /snap/core/10958
/dev/loop14 66M 66M 0 100% /snap/gtk-common-themes/1515
/dev/loop11 52M 52M 0 100% /snap/snap-store/498
/dev/loop12 2.3M 2.3M 0 100% /snap/gnome-system-monitor/157
/dev/loop3 141M 141M 0 100% /snap/gnome-3-26-1604/102
/dev/loop15 52M 52M 0 100% /snap/snap-store/518
/dev/loop13 163M 163M 0 100% /snap/gnome-3-28-1804/145
/dev/loop6 56M 56M 0 100% /snap/core18/1997
/dev/loop8 65M 65M 0 100% /snap/gtk-common-themes/1514
/dev/loop0 141M 141M 0 100% /snap/gnome-3-26-1604/100
/dev/sda3 424G 43G 382G 10% /home
파일시스템을 btrsf를 사용해서 그런걸까 싶어.
이곳저곳의 백업 지우는 방법을 찾아 용량을 확보했는데도 용량이 모자르다고 합니다.
이 다음 무엇을 해보는것이 좋을까요?
