rpi4,pyaudio ALSA 에러
안녕하세요 라파4에 우분투 22.04를 설치하고 아래 파이썬 파일을 실행시키자 다음과 같은 ALSA 에러가 나왔습니다. usb 마이크를 사용해야 하는데 이러네요…ㅠ
해결법 아시는 분 계실까요? ㅠㅠ
import queue
import re
import sys
from google.cloud import speech
import pyaudio
# Audio recording parameters
RATE = 16000
CHUNK = int(RATE / 10)  # 100ms
class MicrophoneStream:
    """Opens a recording stream as a generator yielding the audio chunks."""
    def __init__(self: object, rate: int = RATE, chunk: int = CHUNK) -> None:
        """The audio -- and generator -- is guaranteed to be on the main thread."""
        self._rate = rate
        self._chunk = chunk
        # Create a thread-safe buffer of audio data
        self._buff = queue.Queue()
        self.closed = True
    def __enter__(self: object) -> object:
        self._audio_interface = pyaudio.PyAudio()
        self._audio_stream = self._audio_interface.open(
            format=pyaudio.paInt16,
            # The API currently only supports 1-channel (mono) audio
            # https://goo.gl/z757pE
            channels=1,
            rate=self._rate,
            input=True,
            frames_per_buffer=self._chunk,
            # Run the audio stream asynchronously to fill the buffer object.
            # This is necessary so that the input device's buffer doesn't
            # overflow while the calling thread makes network requests, etc.
            stream_callback=self._fill_buffer,
        self.closed = False
        return self
    def __exit__(
        self: object,
        type: object,
        value: object,
        traceback: object,
    ) -> None:
        """Closes the stream, regardless of whether the connection was lost or not."""
        self._audio_stream.stop_stream()
        self._audio_stream.close()
        self.closed = True
        # Signal the generator to terminate so that the client's
        # streaming_recognize method will not block the process termination.
        self._buff.put(None)
        self._audio_interface.terminate()
    def _fill_buffer(
        self: object,
        in_data: object,
        frame_count: int,
        time_info: object,
        status_flags: object,
    ) -> object:
        """Continuously collect data from the audio stream, into the buffer.
        Args:
            in_data: The audio data as a bytes object
            frame_count: The number of frames captured
            time_info: The time information
            status_flags: The status flags
        Returns:
        self._buff.put(in_data)
        return None, pyaudio.paContinue
    def generator(self: object) -> object:
        """Generates audio chunks from the stream of audio data in chunks.
        Args:
            self: The MicrophoneStream object
        Returns:
            A generator that outputs audio chunks.
        while not self.closed:
            # Use a blocking get() to ensure there's at least one chunk of
            # data, and stop iteration if the chunk is None, indicating the
            # end of the audio stream.
            chunk = self._buff.get()
            if chunk is None:
                return
            data = [chunk]
            # Now consume whatever other data's still buffered.
            while True:
                try:
                    chunk = self._buff.get(block=False)
                    if chunk is None:
                        return
                    data.append(chunk)
                except queue.Empty:
                    break
            yield b"".join(data)
def listen_print_loop(responses: object) -> str:
    """Iterates through server responses and prints them.
    The responses passed is a generator that will block until a response
    is provided by the server.
    Each response may contain multiple results, and each result may contain
    multiple alternatives; for details, see https://goo.gl/tjCPAU.  Here we
    print only the transcription for the top alternative of the top result.
    In this case, responses are provided for interim results as well. If the
    response is an interim one, print a line feed at the end of it, to allow
    the next result to overwrite it, until the response is a final one. For the
    final one, print a newline to preserve the finalized transcription.
    Args:
        responses: List of server responses
    Returns:
        The transcribed text.
    num_chars_printed = 0
    for response in responses:
        if not response.results:
            continue
        # The `results` list is consecutive. For streaming, we only care about
        # the first result being considered, since once it's `is_final`, it
        # moves on to considering the next utterance.
        result = response.results[0]
        if not result.alternatives:
            continue
        # Display the transcription of the top alternative.
        transcript = result.alternatives[0].transcript
        # Display interim results, but with a carriage return at the end of the
        # line, so subsequent lines will overwrite them.
        # If the previous result was longer than this one, we need to print
        # some extra spaces to overwrite the previous result
        overwrite_chars = " " * (num_chars_printed - len(transcript))
        if not result.is_final:
            sys.stdout.write(transcript + overwrite_chars + "\r")
            sys.stdout.flush()
            num_chars_printed = len(transcript)
        else:
            print(transcript + overwrite_chars)
            # Exit recognition if any of the transcribed phrases could be
            # one of our keywords.
            if re.search(r"\b(exit|quit)\b", transcript, re.I):
                print("Exiting..")
                break
    return transcript
def main() -> None:
    """Transcribe speech from audio file."""
    # See http://g.co/cloud/speech/docs/languages
    # for a list of supported languages.
    language_code = "en-US"  # a BCP-47 language tag
    client = speech.SpeechClient()
    config = speech.RecognitionConfig(
        encoding=speech.RecognitionConfig.AudioEncoding.LINEAR16,
        sample_rate_hertz=RATE,
        language_code=language_code,
    streaming_config = speech.StreamingRecognitionConfig(
        config=config, interim_results=True
    with MicrophoneStream(RATE, CHUNK) as stream:
        audio_generator = stream.generator()
        requests = (
            speech.StreamingRecognizeRequest(audio_content=content)
            for content in audio_generator
        responses = client.streaming_recognize(streaming_config, requests)
        # Now, put the transcription responses to use.
        listen_print_loop(responses)
if __name__ == "__main__":
    main()
에러 메세지
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.front.0:CARD=0'
ALSA lib conf.c:5178:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5701:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.surround51.0:CARD=0'
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.surround40.0:CARD=0'
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.surround71.0:CARD=0'
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1369:(snd_func_refer) Unable to find definition 'cards.0.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2'
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2664:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
Cannot connect to server socket err = No such file or directory
Cannot connect to server request channel
jack server is not running or cannot be started
JackShmReadWritePtr::~JackShmReadWritePtr - Init not done for -1, skipping unlock
ALSA lib pcm_oss.c:397:(_snd_pcm_oss_open) Cannot open device /dev/dsp
ALSA lib confmisc.c:160:(snd_config_get_card) Invalid field card
ALSA lib pcm_usb_stream.c:482:(_snd_pcm_usb_stream_open) Invalid card 'card'
ALSA lib pcm_dmix.c:1032:(snd_pcm_dmix_open) unable to open slave
SystemError: PY_SSIZE_T_CLEAN macro must be defined for '#' formats
  File "/home/web/web/stt/stt.py", line 203, in <module>
    main()
  File "/home/web/web/stt/stt.py", line 197, in main
  File "/home/web/.local/lib/python3.10/site-packages/google/cloud/speech_v1/helpers.py", line 81, in streaming_recognize
    return super(SpeechHelpers, self).streaming_recognize(
  File "/home/web/.local/lib/python3.10/site-packages/google/cloud/speech_v1/services/speech/client.py", line 1065, in streaming_recognize
    response = rpc(
  File "/home/web/.local/lib/python3.10/site-packages/google/api_core/gapic_v1/method.py", line 131, in __call__
    return wrapped_func(*args, **kwargs)
  File "/home/web/.local/lib/python3.10/site-packages/google/api_core/retry/retry_unary.py", line 293, in retry_wrapped_func
    return retry_target(
  File "/home/web/.local/lib/python3.10/site-packages/google/api_core/retry/retry_unary.py", line 153, in retry_target
    _retry_error_helper(
  File "/home/web/.local/lib/python3.10/site-packages/google/api_core/retry/retry_base.py", line 212, in _retry_error_helper
    raise final_exc from source_exc
  File "/home/web/.local/lib/python3.10/site-packages/google/api_core/retry/retry_unary.py", line 144, in retry_target
    result = target()
  File "/home/web/.local/lib/python3.10/site-packages/google/api_core/timeout.py", line 120, in func_with_timeout
    return func(*args, **kwargs)
  File "/home/web/.local/lib/python3.10/site-packages/google/api_core/grpc_helpers.py", line 170, in error_remapped_callable
    return _StreamingResponseIterator(
  File "/home/web/.local/lib/python3.10/site-packages/google/api_core/grpc_helpers.py", line 92, in __init__
    self._stored_first_result = next(self._wrapped)
  File "/home/web/.local/lib/python3.10/site-packages/grpc/_channel.py", line 543, in __next__
    return self._next()
  File "/home/web/.local/lib/python3.10/site-packages/grpc/_channel.py", line 960, in _next
    _common.wait(self._state.condition.wait, _response_ready)
  File "/home/web/.local/lib/python3.10/site-packages/grpc/_common.py", line 156, in wait
    _wait_once(wait_fn, MAXIMUM_WAIT_TIMEOUT, spin_cb)
  File "/home/web/.local/lib/python3.10/site-packages/grpc/_common.py", line 116, in _wait_once
    wait_fn(timeout=timeout)
  File "/usr/lib/python3.10/threading.py", line 324, in wait
    gotit = waiter.acquire(True, timeout)
SystemError
WARNING: All log messages before absl::InitializeLog() is called are written to STDERR
E0000 00:00:1731933694.968478   12508 init.cc:229] grpc_wait_for_shutdown_with_timeout() timed out.
